HTTP ERROR 404
Problem accessing /CMD.
Reason: Not Found
Powered by Jetty://
Anyone know what’s going on? I can’t see any specific requirements so figured it’d ‘just work’. If I check http://ohip:8080/rest/items/itemname I get the full rundown of the item, and adding /state show’s me only the state.
I think the REST API has had a major overhaul in OH2 - sorry I am not running that version so can’t confirm. It is possible this CMD? endpoint has been removed/renamed.
OK, thanks. That’s a bit of a shame. The api I’m using (wireless sensor tags) to call the state change doesn’t seem to be sending the right data. I’ll need to dig a little deeper.
@Kai There are references to this method in the wikis so could do with removal or a caveat note on the viability of its use for future users.
