I just picked up a Mimolite to use as a sensor but I’m unable to configure the voltage thresholds like I expect. According to the FortrezZ docs, it looks like I’ll need to be able to set a 1-byte hex value for each of the thresholds: Lower_Threshold_High, Lower_Threshold_Low, Upper_Threshold_High, Upper_Threshold_Low.
However, in both Habmin and Paper UI the input fields for each of these items is a dropdown list which only includes the default value. This only allows me to set the default, I am unable to enter my own value for the threshold, which is required to configure the voltage trigger thresholds. I have other devices where configuration parameters allow free-form text entry for specifying parameter values so I know it’s possible. Am I missing something?
I am running Openhab 2.3.0.
Thanks.
