Cant start a alexa routine
Hello, i can anything use from the Amazon Echo Binding, but not the Item to Start a Routine,
My code simple to start with the play button:
triggers:
conditions:
actions:
  • inputs: {}
    configuration:
    command: starte
    itemName: MichlEchoShow_StartedeineRoutine
    type: core.ItemCommandAction
The debug file shows:
11:03:15.651 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘MichlEchoShow_StartedeineRoutine’ received command starte
11:03:15.657 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘MichlEchoShow_StartedeineRoutine’ predicted to become starte
11:03:22.120 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@77800e8b’: GET url ‘https://alexa.amazon.de/api/behaviors/automations?limit=2000’ failed: Not Found
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url ‘https://alexa.amazon.de/api/behaviors/automations?limit=2000’ failed: Not Found
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:681) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:545) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:540) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getRoutines(Connection.java:1893) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.startRoutine(Connection.java:1824) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:647) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy169.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
11:03:22.183 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘MichlEchoShow_StartedeineRoutine’ changed from starte to
have anybody e hint for me?
have a look to this thread: Limit=2000' failed: Not Found
That thread contains instructions for OH3 and OH2 users to update the related binding as Amazon changed an URL.
great! thats it. i worked on this issue 5 days… Thank you
