Since some time, I cannot update some items via webinterface (Basic UI).
Probably since update 2->3 - but maybe longer. These are items related to heating, so nobody tried to change them during spring/summer.
Other items like switches/Dimmer work fine.
The Items can be updated via console or rule. And if they are updated this way, it is possible to update them via webinterface (till the page is reloaded).
The affected items are not linked to any channels, because they are used in rules only. They are persisted with restoreOnStartup in MapDB. Persistance works fine.
Configuration:
items:
Number:Temperature Lab_Temp_Soll "Soll-Temp Lab-Bereich [%.02f °C]" (Lab, gSetTemperature)
Number:Temperature Buero_Temp_Soll "Soll-Temp Büro [%.02f °C]" (LAB_Buero, gSetTemperature)
Number:Temperature Workshop_Soll "Soll-Temp Besprechungsraum [%.02f °C]" (LAB_Workshop, gSetTemperature)
Number:Temperature Werkstatt_Soll "Soll-Temp Werkstatt [%.02f °C]" (LAB_Workshop, gSetTemperature)
Number:Temperature Lab_Temp_Soll_On "Soll-Temperatur Lab-Bereich beim Öffnen [%.02f °C]" (Lab, gSetTemperatureInitial)
Number:Temperature Buero_Temp_Soll_On "Soll-Temperatur Büro beim Öffnen [%.02f °C]" (LAB_Buero, gSetTemperatureInitial)
Number:Temperature Workshop_Soll_On "Soll-Temperatur Besprechungsraum beim Öffnen [%.02f °C]" (LAB_Workshop, gSetTemperatureInitial)
Number:Temperature Werkstatt_Soll_On "Soll-Temperatur Werkstatt beim Öffnen [%.02f °C]" (LAB_Workshop, gSetTemperatureInitial)
Number:Temperature Lab_Temp_Soll_Off "Soll-Temperatur Lab-Bereich beim Schließen [%.02f °C]" (Lab, gSetTemperatureInitial)
Number:Temperature Buero_Temp_Soll_Off "Soll-Temperatur Büro beim Schließen [%.02f °C]" (LAB_Buero, gSetTemperatureInitial)
Number:Temperature Workshop_Soll_Off "Soll-Temperatur Besprechungsraum beim Schließen [%.02f °C]" (LAB_Workshop, gSetTemperatureInitial)
Number:Temperature Werkstatt_Soll_Off "Soll-Temperatur Werkstatt beim Schließen [%.02f °C]" (LAB_Workshop, gSetTemperatureInitial)
Sitemap (relevant part):
Text item=gSetTemperatureInitial label="Initiale Soll-Temperatur" icon="temperature" {
Frame label="Soll-Temperatur aktuell" {
Setpoint item=Workshop_Soll label="Workshopraum" minValue=16 maxValue=26 step=0.25
Setpoint item=Buero_Temp_Soll label="Büro" minValue=16 maxValue=26 step=0.25
Setpoint item=Werkstatt_Soll label="Werkstatt" minValue=16 maxValue=26 step=0.25
Setpoint item=Lab_Temp_Soll label="*space" minValue=16 maxValue=26 step=0.25
Frame label="Ist-Temperaturen" {
Default item=bzesp60da0e_bme280_temperature label="Workshopraum"
Default item=Buero_Temperature label="Büro"
Default item=weesp60db41_bme280_temperature label="Werkstatt"
Default item=e1esp60dab3_bme280_temperature label="*space E1 (Textil)"
Default item=i3esp60db49_bme280_temperature label="*space I3"
Text label="Parametrierung der inialen Solltemperaturen für die Räume bei Lab offen bzw. geschlossen - BITTE NUR MIT BEDACHT ÄNDERN!"
Frame label="Soll-Temperatur beim Öffnen des Lab" {
Setpoint item=Workshop_Soll_On label="Workshopraum" minValue=16 maxValue=26 step=0.25
Setpoint item=Buero_Temp_Soll_On label="Büro" minValue=16 maxValue=26 step=0.25
Setpoint item=Werkstatt_Soll_On label="Werkstatt" minValue=16 maxValue=26 step=0.25
Setpoint item=Lab_Temp_Soll_On label="*space" minValue=16 maxValue=26 step=0.25
Frame label="Soll-Temperatur beim Schließen des Lab" {
Setpoint item=Workshop_Soll_Off label="Workshopraum" minValue=16 maxValue=26 step=0.25
Setpoint item=Buero_Temp_Soll_Off label="Büro" minValue=16 maxValue=26 step=0.25
Setpoint item=Werkstatt_Soll_Off label="Werkstatt" minValue=16 maxValue=26 step=0.25
Setpoint item=Lab_Temp_Soll_Off label="*space" minValue=16 maxValue=26 step=0.25
Frame label="Rule-Test" {
Default item=LabPowerS_Test label="Fake Lab-Zustand ein/aus"
