Car Presence
I have been using MQTT Car Presence with OH for a couple of months. One main problem I had to solve was the timing/order MQTT messages are received to have the functionality I wanted. See [Asynchronous Events to Synchronous Event](http://Async to Sync tutorial). This must be setup before using the example below.
MQTT Car presence follows the Home Assistant MQTT protocol. In this example, I use the Things that are created by the OpenHAB MQTT binding but manually define the Items. All logic is done in Jython.
Items
Group gVehicles "Vehicles" (gContext)
Group gCars "Cars" (gVehicles)
Group CAR_AudiQ7 (gAsync_to_Sync_Aggregator) {Async_Time=".5"}
Switch CAR_AudiQ7_Online_Switch "Audi Q7 Online" (gCars,Car_AudiQ7) {channel="mqtt:homeassistant_AudiQ7:Queen:AudiQ7:AudiQ7_5Fbinary_5Fsensor#sensor",Async_Time="300"}
Number CAR_AudiQ7_WIFI_Signal_Strength "Audi Q7 Signal" (gCars,Car_AudiQ7) {channel="mqtt:homeassistant_AudiQ7_2Dsignal:Queen:AudiQ7_2Dsignal:AudiQ7_2Dsignal_5Fsensor#sensor"}
Number CAR_AudiQ7_Uptime_Seconds "Audi Q7 Uptime" (gCars,Car_AudiQ7) {channel="mqtt:homeassistant_AudiQ7_2Duptime:Queen:AudiQ7_2Duptime:AudiQ7_2Duptime_5Fsensor#sensor"}
Switch CAR_AudiQ7_At_Home "Audi Q7 At Home" (gCars)
Switch CAR_AudiQ7_Sync_Switch (gAsync_to_Sync_Proxy_Switches)
Group CAR_SubaruOutback (gAsync_to_Sync_Aggregator) {Async_Time=".5"}
Switch CAR_SubaruOutback_Online_Switch "Outback Q7 Online" (gCars,CAR_SubaruOutback) {channel="mqtt:homeassistant_SubaruOutback:Queen:SubaruOutback:SubaruOutback_5Fbinary_5Fsensor#sensor",Async_Time="300"}
Number CAR_SubaruOutback_WIFI_Signal_Strength "Outback Signal" (gCars,CAR_SubaruOutback) {channel="mqtt:homeassistant_SubaruOutback_2Dsignal:Queen:SubaruOutback_2Dsignal:SubaruOutback_2Dsignal_5Fsensor#sensor"}
Number CAR_SubaruOutback_Uptime_Seconds "Outback Uptime" (gCars,CAR_SubaruOutback) {channel="mqtt:homeassistant_SubaruOutback_2Duptime:Queen:SubaruOutback_2Duptime:SubaruOutback_2Duptime_5Fsensor#sensor"}
Switch CAR_SubaruOutback_At_Home "Outback At Home" (gCars)
Switch CAR_SubaruOutback_Sync_Switch (gAsync_to_Sync_Proxy_Switches)
Jython
@rule ("AudiQ7 online")
@when ("Item CAR_AudiQ7_Sync_Switch changed to ON")
def audi_in_sync (event):
uptime = int(ir.getItem("CAR_AudiQ7_Uptime_Seconds").state.toString())
signal = int(ir.getItem("CAR_AudiQ7_WIFI_Signal_Strength").state.toString())
if ir.getItem("CAR_AudiQ7_Online_Switch").state==ON:
events.sendCommand(ir.getItem("CAR_AudiQ7_At_Home"),ON)
if uptime > 60000: #been running for 1 min before getting ON therefore assume car arriving
if ir.getItem("EX_Garage_DoubleDoor_Sensor").state == CLOSED:
events.sendCommand (ir.getItem ("EX_Garage_OperateDoubleDoor_Button"), ON)
@rule ("AudiQ7 offline")
@when ("Item CAR_AudiQ7_Online_Switch changed to OFF")
def audi_offline (event):
if signal < -70:# if signal < -70 when turning off, assume car is leaving
events.sendCommand(ir.getItem("CAR_AudiQ7_At_Home"),OFF)
#close garage door if its open and not currently moving
if ir.getItem("EX_Garage_DoubleDoor_Sensor").state == OPEN:
if ir.getItem("EX_Garage_DoubleDoor_Moving_Switch").state == OFF: # make sure not closing
else:
@rule ("SubaruOutback online")
@when ("Item CAR_SubaruOutback_Sync_Switch changed to ON")
def subaru_in_sync (event):
uptime = int(ir.getItem("CAR_SubaruOutback_Uptime_Seconds").state.toString())
signal = int(ir.getItem("CAR_SubaruOutback_WIFI_Signal_Strength").state.toString())
if ir.getItem("CAR_SubaruOutback_Online_Switch").state==ON:
events.sendCommand(ir.getItem("CAR_SubaruOutback_At_Home"),ON)
if ir.getItem("EX_Garage_SingleDoor_Sensor").state == CLOSED:
events.sendCommand (ir.getItem ("EX_Garage_OperateSingleDoor_Button"), ON)
@rule ("SubaruOutback offline")
@when ("Item CAR_SubaruOutback_Online_Switch changed to OFF")
def subaru_offline (event):
events.sendCommand(ir.getItem("CAR_SubaruOutback_At_Home"),OFF)
if ir.getItem("EX_Garage_SingleDoor_Sensor").state == OPEN:
if ir.getItem("EX_Garage_SingleDoor_Moving_Switch").state == OFF: # make sure not closing
else:
