Phone screen recording, showing widget’s usage
Git repository
My version of cell widget for rooms of my house, small cells will popup a bigger widget on click, giving more options and controls (from the smaller widget only light controls will popup if you’ll manage to click exactly on lightbulb button - that is made for faster access to the most used control).
Smaller widget will pass all options it has to the bigger one, so despite of the fact that smaller version doesn’t show all items which are passed to it, you’ll still need to fill in all those items you want to see in popup.
Widget is designed to fit dark and bright color themes, changing it’s colors depending of user theme, and is designed to provide clear view on background image, so it’s full off css shadows, and maybe if you don’t need/don’t like all those shadows, you should delete them in widget code to get a bit more of performance.
Widget’s remote control is designed for Samsung TV, using Samsung TV’s binding, so if your TV is different, you will not get all those keys working.
So the cell widget code is:
uid: Cell_Temp_Card_3
tags:
- co
- humidity
- motion
- temperature
props:
parameters:
- description: Title on top of the card
label: Title
required: false
type: TEXT
groupName: general
- description: Icon on top of the card (only f7 icons (without f7:))
label: Icon
required: false
type: TEXT
groupName: general
- description: Background image name
label: Background image
required: false
type: TEXT
groupName: general
- description: in rgba() or HEX or empty
label: Background Color
required: false
type: TEXT
groupName: general
- context: item
description: An item, measuring room's temperature
label: Temperature sensor
required: false
type: TEXT
groupName: sensors
- context: item
description: An item, measuring room's light level
label: Lightlevel sensor
required: false
type: TEXT
groupName: sensors
- context: item
description: An item, measuring room's humidity
label: Humidity sensor
required: false
type: TEXT
groupName: sensors
- context: item
description: An item, measuring room's CO2 level
label: CO2 sensor
required: false
type: TEXT
groupName: sensors
- context: item
description: An item, setting room's desired temperature
label: Target Temperature
required: false
type: TEXT
groupName: climate
- context: item
description: An item, setting room's desired humidity
label: Target Humidity
required: false
type: TEXT
groupName: climate
- context: item
description: An item to switch cooling On/Off
label: Cooling On/Off
required: false
type: TEXT
groupName: climate
- context: item
description: An item to switch heating On/Off
label: Heating On/Off
required: false
type: TEXT
groupName: climate
- context: item
description: An item to switch humidifier On/Off
label: Humidifier On/Off
required: false
type: TEXT
groupName: climate
- context: item
description: Main climate fan speeed
label: Fanspeed
required: false
type: TEXT
groupName: climate
- context: item
description: An item to switch fan On/Off
label: Fan on/off
required: false
type: TEXT
- context: item
description: An item to choose humidifier fan's speed
label: Humidifier fan speed
required: false
type: TEXT
groupName: climate
- context: item
description: Motion sensor
label: Motion item
required: false
type: TEXT
groupName: security
- context: item
description: A group, containing all kind of lights - On/Off, Dimmers, Colorlights, widget will try to show them, by reading their tags.
label: Lights group
required: false
type: TEXT
- context: item
label: Door item
required: false
type: TEXT
groupName: security
- context: item
label: Lock item
required: false
type: TEXT
groupName: security
- context: item
label: Window item
required: false
type: TEXT
groupName: security
- context: item
label: Leakage item
required: false
type: TEXT
groupName: security
- context: item
label: Smoke item
required: false
type: TEXT
groupName: security
- context: item
description: SamsungTV or Kodi Media title
label: Media Title
required: false
type: TEXT
groupName: media
- context: item
description: TV power On/Off, widget will hide media remote section if this item is not set
label: Power Item
required: false
type: TEXT
groupName: media
- context: item
description: TV channel item, if present
label: Channel
required: false
type: TEXT
groupName: media
- context: item
description: Samsung TV KeyCode channel
label: Key Code
required: false
type: TEXT
groupName: media
- context: item
description: Volume control item, if present, any dimmer type item
label: Volume Control Item
required: false
type: TEXT
groupName: media
- context: item
description: SamsungTV source name, or Kodi Media title, or any other item to show on remote's screen
label: Source Name
required: false
type: TEXT
groupName: media
parameterGroups:
- name: general
label: General settings
- name: sensors
label: Sensors settings
- name: media
label: Media group settings
- name: climate
label: Climate settings
- name: security
label: Security settings
timestamp: Sep 19, 2022, 2:18:30 AM
component: f7-card
style:
background: transparent
background-brightness: 60%
background-color: "=props.bgcolor ? props.bgcolor : ''"
background-image: "=props.bg_image_url ? 'url(/static/' + (props.bg_image_url) + ')' : ''"
background-position: center
background-repeat: no-repeat
background-size: cover
box-shadow: 5px 5px 10px 1px var(--f7-bars-bg-color)
color: var(--f7-text-color)
font-size: medium
font-weight: 500
height: 150px
margin: 5
noShadow: false
padding: 0
text-shadow: 1px 0px 2px var(--f7-bars-bg-color), -1px 0px 2px var(--f7-bars-bg-color), 0px 0px 2px var(--f7-bars-bg-color), 0px 0px 3px var(--f7-bars-bg-color)
slots:
default:
- component: f7-card-header
style:
justify-content: center
margin: 0
min-height: 30px
padding: 0
slots:
default:
- component: f7-icon
f7: =props.icon
visible: "=props.icon ? true : false"
- component: Label
style:
font-size: 18px
font-weight: bold
margin-left: 5px
text: "=props.title ? props.title : ''"
- component: f7-card-content
style:
align-items: flex-start
display: flex
justify-content: space-between
margin: 7px
padding: 0
slots:
default:
- component: f7-col
config: {}
slots:
default:
- component: f7-row
style:
flex-wrap: nowrap
justify-content: flex-start
visible: "=props.temp_item ? true : false"
slots:
default:
- component: oh-icon
icon: martinitemp
state: =items[props.temp_item].state
style:
filter: drop-shadow(3px 2px 2px rgb(0 0 0 / 0.4))
width: 23
- component: Label
style:
color: '=(Number.parseFloat(items[props.temp_item].state.split(" ")[0]) > 30) ? "rgb(242,75,36)" : (Number.parseFloat(items[props.temp_item].state.split(" ")[0]) < 10) ? "rgba(32, 185, 256,0.8)" : "var(--f7-text-color)"'
margin-left: 5px
text: =Number.parseInt(items[props.temp_item].state)+" °C"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.humidity_item ? true : false"
slots:
default:
icon: hum
state: =items[props.humidity_item].state
style:
width: 23
- component: Label
style:
margin-left: 5px
text: =Number.parseInt(items[props.humidity_item].state) +" %"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.lightlevel_item ? true : false"
slots:
default:
icon: lightlevel
state: =items[props.lightlevel_item].state
style:
width: 23
- component: Label
style:
color: "=(items[props.lightlevel_item].state < 1) ? 'gray' : 'var(--f7-text-color)'"
margin-left: 5px
text: =Number.parseInt(items[props.lightlevel_item].state) +" lux"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.CO_item ? true : false"
slots:
default:
icon: carbondioxidecloud
state: =items[props.CO_item].state
style:
width: 23
- component: Label
style:
color: '=(Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1500) ? "red" : (Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1000) ? "yellow" : "var(--f7-text-color)"'
margin-left: 5px
white-space: nowrap
text: =Number.parseInt(items[props.CO_item].state) +" ppm"
- component: f7-col
style:
align-items: center
display: flex
flex-direction: column
slots:
default:
- component: f7-row
style:
z-index: 1
visible: "=props.motion_item ? true : false"
slots:
default:
icon: f7:dot_radiowaves_left_right
width: 25
style:
color: '=(items[props.motion_item].state == "ON") ? "red" : "var(--f7-text-color)"'
- component: f7-row
style:
z-index: 1
visible: "=props.motion_item || props.door_item || props.lock_item || props.window_item ? true : false"
slots:
default:
icon: "=(items[props.lock_item].state === 'ON') ? 'f7:lock' : 'f7:lock_open'"
visible: "=props.lock_item ? true : false"
width: 25
icon: "=(items[props.door_item].state === 'ON') ? 'door-closed' : 'door-open'"
visible: "=props.door_item ? true : false"
width: 25
icon: "=(items[props.window_item].state === 'ON') ? 'window' : 'window-open'"
visible: "=props.window_item ? true : false"
width: 25
- component: oh-button
action: group
actionGroupPopupItem: =props.light
style:
padding: 0
z-index: 99
visible: "=props.light ? true : false"
slots:
default:
width: 30
icon: '=(items[props.light].state == "ON") ? "f7:lightbulb_fill" : "f7:lightbulb"'
item: =loop.item.name
style:
color: '=(items[props.light].state == "ON") ? "yellow" : "var(--f7-text-color)"'
- component: oh-link
action: popup
actionModal: widget:Cell_Temp_Card_Expanded
actionModalConfig:
CO_item: =props.CO_item
bg_image_url: =props.bg_image_url
bgcolor: =props.bgcolor
channel: =props.channel
door_item: =props.door_item
humidity_item: =props.humidity_item
humidityset_item: =props.humidityset_item
icon: =props.icon
inputAction: =props.inputAction
leakage_item: =props.leakage_item
light: =props.light
lightlevel_item: =props.lightlevel_item
lock_item: =props.lock_item
mediaTitle: =props.
motion_item: =props.motion_item
power: =props.power
smoke_item: =props.smoke_item
sourceName: =props.sourceName
temp_item: =props.temp_item
temperatureset_item: =props.temperatureset_item
humidifieron_item: =props.humidifieron_item
fanspeed_item: =props.fanspeed_item
fanon_item: =props.fanon_item
humidifierfan_item: =props.humidifierfan_item
title: =props.title
volumeControlItem: =props.volumeControlItem
window_item: =props.window_item
style:
height: 137px
left: 0px
margin: 0px
padding: 0
position: absolute
top: -30px
width: 100%
z-index: 3
And popup widget code is:
uid: Cell_Temp_Card_Expanded
tags:
- co
- humidity
- motion
- temperature
props:
parameters:
label: Title
required: false
type: TEXT
label: Icon
required: false
type: TEXT
required: false
type: TEXT
required: false
type: TEXT
- context: item
label: Temperature
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: Lightlevel
required: false
type: TEXT
- context: item
label: Humidity
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: Fanspeed
required: false
type: TEXT
- context: item
label: Fan on/off
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: CO
required: false
type: TEXT
- context: item
label: Motion item
required: false
type: TEXT
- context: item
label: Lights group
required: false
type: TEXT
- context: item
label: Door item
required: false
type: TEXT
- context: item
label: Lock item
required: false
type: TEXT
- context: item
label: Window item
required: false
type: TEXT
- context: item
label: Leakage item
required: false
type: TEXT
- context: item
label: Smoke item
required: false
type: TEXT
- context: item
label: Media Title
required: false
type: TEXT
- context: item
label: Power Item
required: false
type: TEXT
- context: item
label: Channel
required: false
type: TEXT
- context: item
label: Key Code
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: Source Name
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 19, 2022, 2:17:59 AM
component: f7-card
style:
--f7-badge-text-color: var(--f7-text-color)
--f7-bars-bg-color: none
--f7-bars-border-color: none
--f7-bars-translucent-blur: none
--f7-bars-translucent-opacity: none
--f7-navbar-link-color: var(--f7-text-color)
--f7-navbar-shadow-image: none
--f7-page-content-extra-padding-bottom: none
--f7-page-content-extra-padding-top: none
--f7-page-searchbar-offset: none
--f7-page-subnavbar-offset: none
--f7-page-toolbar-bottom-offset: none
--f7-page-toolbar-top-offset: none
--f7-range-label-text-color: var(--f7-text-color)
--f7-range-label-bg-color: var(--f7-card-bg-color)
--f7-range-label-font-size: 16px
--f7-range-label-font-weight: 500
--popup-text-shadow-light: 2px 2px rgba(var(--f7-card-bg-color),.15)
--popup-text-shadow-strong: 2px 2px rgba(var(--f7-card-bg-color),.35)
background-position: down
box-shadow: 5px 5px 10px 1px var(--f7-card-bg-color)
font-size: large
font-weight: 600
height: 100%
margin: 0
noShadow: false
overflow: hidden
text-shadow: 0.031250em 0.031250em 0.015625em var(--f7-card-bg-color), -0.015625em -0.015625em 0.187500em var(--f7-card-bg-color), -0.006250em -0.006250em 0.187500em var(--f7-card-bg-color)
slots:
default:
style:
display: flex
margin: 0
min-height: 35px
padding: 0
slots:
default:
f7: =props.icon
- component: Label
style:
font-size: 20px
font-weight: bold
margin-left: 5px
style:
margin: 0
padding: 0
slots:
default:
- component: f7-row
slots:
default:
- component: f7-segmented
color: gray
raised: false
strong: true
style:
width: 100%
backdrop-filter: blur(5px)
slots:
default:
action: variable
actionVariable: select
actionVariableValue: 1
active: =(vars.select == 1)
iconF7: thermometer
iconSize: 40
large: true
outline: =(vars.select == 1)
style:
height: 45px
action: variable
actionVariableValue: 2
active: =(vars.select == 2)
iconF7: thermometer_snowflake
iconSize: 40
large: true
outline: =(vars.select == 2)
visible: "=props.temperatureset_item || props.humidityset_item || props.fanon_item || props.coolingon_item || props.heatingon_item ? true : false"
style:
height: 45px
action: variable
actionVariableValue: 3
active: =(vars.select == 3)
iconF7: film
iconSize: 40
large: true
outline: =(vars.select == 3)
visible: "=props.power ? true : false"
style:
height: 45px
action: variable
actionVariableValue: 4
active: =(vars.select == 4)
iconF7: shield
iconSize: 40
large: true
outline: =(vars.select == 4)
visible: "=props.lock_item || props.door_item || props.window_item || props.motion_item || props.leakage_item ? true : false"
style:
height: 45px
action: variable
actionVariableValue: 5
active: =(vars.select == 5)
iconF7: graph_square
iconSize: 40
large: true
outline: =(vars.select == 5)
style:
height: 45px
- component: f7-tab
class:
- display-flex
- justify-content-space-between
- flex-direction-column
style:
animation: f7-fade-in 300ms
margin: 5px
padding: 0px
visible: =(vars.select == 1 || vars.select == NULL)
slots:
default:
- component: f7-row
style:
border-bottom: 1px solid
filter: drop-shadow(0px 0px 1px var(--f7-card-bg-color))
margin: 10px
slots:
default:
- component: f7-col
style:
width: auto
slots:
default:
- component: f7-row
style:
flex-wrap: nowrap
slots:
default:
icon: martinitemp
width: 30
- component: Label
style:
margin-left: 5px
text: =items[props.temp_item].state.split(" ")[0]+" °C"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
slots:
default:
icon: hum
width: 30
- component: Label
style:
color: '=(Number.parseFloat(items[props.humidity_item].state.split(" ")[0]) < 35) ? "rgb(242,75,36)" : (Number.parseFloat(items[props.humidity_item].state.split(" ")[0]) > 75) ? "green" : "var(--f7-text-color)"'
margin-left: 5px
text: =items[props.humidity_item].state.split(" ")[0]+" %"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
slots:
default:
icon: lightlevel
width: 30
- component: Label
style:
margin-left: 5px
text: =items[props.lightlevel_item].state.split(" ")[0]+" lux"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
slots:
default:
width: 30
- component: Label
style:
color: '=(Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1500) ? "red" : (Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1000) ? "orange" : "var(--f7-text-color)"'
margin-left: 5px
white-space: nowrap
text: =items[props.CO_item].state.split(" ")[0]+" ppm"
- component: f7-col
style:
align-items: center
display: flex
justify-content: flex-end
width: auto
slots:
default:
- component: f7-col
style:
z-index: 1
visible: "=props.motion_item || props.lock_item ? true : false"
slots:
default:
action: analyzer
actionAnalyzerItems: =[props.motion_item]
large: true
slots:
default:
width: 40
style:
action: toggle
actionCommand: ON
actionCommandAlt: OFF
actionItem: =[props.lock_item]
large: true
slots:
default:
style:
width: 30
- component: f7-col
style:
z-index: 1
visible: "=props.door_item || props.window_item ? true : false"
slots:
default:
width: 25
width: 25
- component: f7-block
style:
font-size: medium
font-weight: 600
margin: 5px
padding: 0px
slots:
default:
- component: oh-repeater
fetchMetadata: semantics,metadata
filter: '(loop.switchItem.type=="Switch") ? true : false'
for: switchItem
groupItem: =props.light
sourceType: itemsInGroup
slots:
default:
- component: f7-row
style:
margin-bottom: 5px
slots:
default:
height: 30
icon: '=(items[loop.switchItem.name].state == "ON") ? "f7:lightbulb_fill" : "f7:lightbulb"'
style:
color: '=(items[loop.switchItem.name].state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
text: =loop.switchItem.label
- component: oh-toggle
color: yellow
item: =loop.switchItem.name
style:
--f7-toggle-height: 23px
--f7-toggle-width: 55px
--f7-toggle-inactive-color: rgba(100,100,100,0.8)
margin-left: auto
filter: '(loop.dimmerItem.type=="Dimmer") ? true : false'
for: dimmerItem
slots:
default:
- component: f7-row
style:
margin-bottom: 5px
slots:
default:
height: 30
icon: f7:sun_max
style:
color: '=(loop.dimmerItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
margin-right: auto
text: =loop.dimmerItem.label
- component: oh-slider
color: white
item: =loop.dimmerItem.name
label: true
max: '=(loop.dimmerItem.stateDescription && loop.dimmerItem.stateDescription.maximum) ? loop.dimmerItem.stateDescription.maximum : "100"'
style:
--f7-range-bar-active-bg-color: linear-gradient(to right, rgba(30,30,0,0.1), rgba(255,255,0,1))
--f7-range-bar-bg-color: linear-gradient(to right, rgba(50,50,0,0.1), rgba(255,255,0,1))
--f7-range-bar-border-radius: 10px
--f7-range-bar-size: 20px
--f7-range-knob-box-shadow: 0 2px 4px black
--f7-range-knob-size: 25px
margin-left: auto
margin-right: auto
width: 90%
filter: 'loop.colorTempItem.metadata.semantics.config.relatesTo == "Property_ColorTemperature" ? true : false'
for: colorTempItem
slots:
default:
- component: f7-row
style:
margin-bottom: 5px
slots:
default:
height: 30
icon: f7:dial
style:
color: '=(loop.colorTempItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
margin-right: auto
text: =loop.colorTempItem.label
item: =loop.colorTempItem.name
label: true
max: 6500
min: 1700
color: white
style:
--f7-range-bar-active-bg-color: rgba(255, 121, 0,0.1)
--f7-range-bar-bg-color: linear-gradient(to right, rgba(255, 121, 0,0.5), rgba(200, 249, 253,1))
--f7-range-knob-box-shadow: 0 2px 4px rgba(0, 0, 0, 0.3)
margin-left: auto
margin-right: auto
width: 90%
filter: '(loop.colorItem.type=="Color") ? true : false'
for: colorItem
slots:
default:
- component: f7-row
style:
margin-bottom: 5px
--f7-color-picker-slider-size: 15px
--f7-color-picker-slider-knob-size: 25px
slots:
default:
height: 30
icon: f7:slider_horizontal_3
style:
color: '=(loop.colorItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
margin-right: auto
text: =loop.colorItem.label
- component: oh-colorpicker
item: =loop.colorItem.name
modules:
- hsb-sliders
- component: f7-tab
class:
- display-flex
style:
margin: 5px
padding: 0px
visible: =(vars.select == 2)
slots:
default:
color: gray
raised: false
strong: true
style:
width: 100%
slots:
default:
action: toggle
actionItem: =props.heatingon_item
actionCommand: ON
active: '=(items[props.heatingon_item].state == "ON") ? true : false'
iconF7: thermometer_sun
large: true
outline: '=(items[props.heatingon_item].state == "ON") ? true : false'
visible: "=props.heatingon_item ? true : false"
action: toggle
actionItem: =props.coolingon_item
actionCommand: ON
active: '=(items[props.coolingon_item].state == "ON") ? true : false'
large: true
outline: '=(items[props.coolingon_item].state == "ON") ? true : false'
visible: "=props.coolingon_item ? true : false"
action: toggle
actionItem: =props.fanon_item
actionCommand: ON
active: '=(items[props.fanon_item].state == "ON") ? true : false'
iconF7: wind
large: true
outline: '=(items[props.fanon_item].state == "ON") ? true : false'
visible: "=props.fanon_item ? true : false"
action: toggle
actionItem: =props.humidifieron_item
actionCommand: ON
active: '=(items[props.humidifieron_item].state == "ON") ? true : false'
iconF7: drop
large: true
outline: '=(items[props.humidifieron_item].state == "ON") ? true : false'
visible: "=props.humidifieron_item ? true : false"
style:
display: flex
width: 100%
slots:
default:
- component: f7-col
style:
margin: auto
visible: "=props.temperatureset_item ? true : false"
slots:
default:
- component: f7-col
config: {}
slots:
default:
- component: Label
style:
text: Target temperature
- component: oh-stepper
autorepeat: true
step: 0.5
raised: true
round: true
fill: true
item: =(props.temperatureset_item)
style:
--f7-stepper-fill-button-bg-color: rgba(255, 0, 0, 0.4)
--f7-stepper-value-text-color: var(--f7-text-color)
--f7-stepper-height: 40px
--f7-stepper-raised-box-shadow: 2px 3px 10px rgba(0, 0, 0, 0.5), -2px -2px 10px rgba(0, 0, 0, 0.5)
--f7-stepper-value-font-weight: 600
--f7-stepper-border-width: 0px
- component: f7-col
visible: "=props.fanspeed_item ? true : false"
slots:
default:
- component: Label
style:
text: Fan mode
min: 1
max: 4
round: true
raised: true
fill: true
style:
--f7-stepper-fill-button-bg-color: rgba(0, 0, 255, 0.4)
- component: f7-col
style:
margin: auto
visible: "=props.humidityset_item ? true : false"
slots:
default:
- component: f7-col
config: {}
slots:
default:
- component: Label
style:
text: Target humidity
autorepeat: true
autorepeatDynamic: true
round: true
raised: true
fill: true
style:
--f7-stepper-fill-button-bg-color: rgba(0, 255, 255, 0.4)
- component: f7-col
visible: "=props.humidifierfan_item ? true : false"
slots:
default:
- component: Label
style:
text: Humidifier fan mode
min: 1
max: 4
round: true
raised: true
fill: true
style:
- component: f7-tab
class:
- display-flex
style:
font-weight: 600
margin: 5px
margin-right: 5px
padding: 0px
text-shadow: 1px 1px 1px var(--f7-card-bg-color), -1px -1px 1px var(--f7-card-bg-color), 1px -1px 1px var(--f7-card-bg-color), -1px 1px 1px var(--f7-card-bg-color)
visible: =(vars.select == 3)
slots:
default:
style:
height: 70px
slots:
default:
large: true
raised: true
style:
box-shadow: 0px 2px 5px
height: 40px
line-height: 1.5
top: 5px
white-space: pre-wrap
word-break: break-word
text: "=(items[props.sourceName].state !== 'UNDEF' ? (items[props.sourceName].state +' '+ items[props.mediaTitle].state) : items[props.mediaTitle].state)"
textColor: var(--f7-text-color)
style:
width: auto
slots:
default:
- component: f7-row
config: {}
slots:
default:
action: command
actionCommand: "=(items[props.power].state === 'OFF') ? 'ON' : 'OFF' "
actionItem: =props.power
iconF7: power
iconSize: 20
style:
background-image: "linear-gradient(360deg, #1C1C1C 10%, #494949 360%)"
border-radius: 12px
box-shadow: 0px 2px 2px
color: "=(items[props.power].state === 'OFF') ? 'var(--f7-text-color)' : 'red' "
width: 25%
action: command
actionCommand: KEY_HOME
actionItem: =props.inputAction
iconF7: house
iconSize: 20
style:
border-radius: 12px
width: 25%
action: command
actionCommand: KEY_MENU
iconF7: menu
iconSize: 20
style:
border-radius: 12px
width: 25%
- component: f7-row
style:
height: 37px
margin-top: 5px
width: 100%
slots:
default:
round: true
strong: true
style:
--f7-segmented-strong-between-buttons: 3px
--f7-segmented-strong-padding: 0px
border-radius: 12px
box-shadow: 1px 0px 8px
width: 100%
slots:
default:
action: command
actionCommand: INCREASE
actionItem: =props.volumeControlItem
iconF7: speaker_3
iconSize: 25
style:
border-right: 1px solid gray
width: 50%
action: command
actionCommand: KEY_CHUP
iconF7: arrow_up
iconSize: 25
style:
border-left: 1px solid gray
width: 50%
- component: f7-row
style:
width: 100%
slots:
default:
round: true
strong: true
style:
border-radius: 12px
box-shadow: 1px 0px 5px
width: 100%
slots:
default:
action: command
actionCommand: DECREASE
bgColor: black
iconF7: speaker_1
iconSize: 25
style:
width: 50%
action: command
actionCommand: KEY_CHDOWN
bgColor: black
iconF7: arrow_down
iconSize: 25
style:
width: 50%
- component: f7-row
style:
margin-top: 10px
slots:
default:
action: command
actionCommand: KEY_RED
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: red
width: 20%
action: command
actionCommand: KEY_GREEN
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: green
width: 20%
action: command
actionCommand: KEY_YELLOW
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: yellow
width: 20%
action: command
actionCommand: KEY_BLUE
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: blue
width: 20%
- component: f7-row
style:
margin-top: 10px
slots:
default:
action: command
actionCommand: KEY_REWIND
bgColor: black
iconF7: backward_end
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_STOP
bgColor: black
iconF7: stop
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_PLAY
bgColor: black
iconF7: playpause
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_FF
bgColor: black
iconF7: forward_end
iconSize: 20
style:
border-radius: 12px
width: 20%
style:
height: 220px
width: auto
slots:
default:
action: command
actionCommand: KEY_EXIT
style:
border-radius: 12px
left: 10%
position: absolute
top: 15px
width: 70px
text: EXIT
action: command
style:
border-radius: 12px
position: absolute
right: 10%
top: 15px
width: 70px
text: MENU
action: command
actionCommand: KEY_MUTE
iconF7: speaker_slash
iconSize: 25
style:
border-radius: 12px
color: red
left: 50%
position: absolute
top: 15px
transform: translate(-50%)
action: command
actionCommand: KEY_RETURN
iconF7: arrow_counterclockwise
iconSize: 25
style:
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
left: 10%
position: absolute
top: 60px
transform: skew(140deg)
width: 15%
z-index: 2
- component: f7-badge
bgColor: gray
style:
background-image: "linear-gradient(300deg, #1C1C1C 10%, #494949 360%)"
border-radius: 100px/100px
height: 160px
left: 50%
position: absolute
top: 60px
width: 160px
z-index: 1
bgColor: black
style:
background-image: "linear-gradient(360deg, #1C1C1C 1%, #494949 90%)"
border-radius: 60px
height: 60px
left: 50%
position: absolute
top: 110px
width: 60px
z-index: 3
action: command
actionCommand: KEY_ENTER
style:
font-size: 18px
left: 50%
position: absolute
top: 125px
z-index: 3
text: OK
action: command
actionCommand: KEY_UP
iconF7: arrowtriangle_up
iconSize: 35
style:
left: 50%
position: absolute
top: 67px
z-index: 2
action: command
actionCommand: KEY_LEFT
iconF7: arrowtriangle_left
iconSize: 35
style:
left: 50%
position: absolute
top: 120px
transform: translate(-75px)
z-index: 2
action: command
actionCommand: KEY_RIGHT
iconF7: arrowtriangle_right
iconSize: 35
style:
left: 50%
position: absolute
top: 120px
transform: translate(45px)
z-index: 2
action: command
actionCommand: KEY_DOWN
iconF7: arrowtriangle_down
iconSize: 35
style:
left: 50%
position: absolute
top: 180px
z-index: 2
action: command
actionCommand: left
actionItem: =props.inputaction
iconF7: circle
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
position: absolute
right: 10%
top: 60px
transform: skew(40deg)
width: 15%
z-index: 2
action: command
actionCommand: KEY_GUIDE
iconF7: doc_plaintext
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
left: 10%
position: absolute
top: 180px
width: 15%
z-index: 2
action: command
actionCommand: KEY_INFO
iconF7: info_circle
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
position: absolute
right: 10%
top: 180px
width: 15%
z-index: 2
- component: f7-tab
style:
filter: drop-shadow(0px 1px 1px var(--f7-card-bg-color))
margin: 5px
margin-right: 5px
padding: 0px
visible: =(vars.select == 4)
slots:
default:
- component: oh-list
config: {}
slots:
default:
- component: oh-list-item
accordionItem: true
action: toggle
actionCommand: ON
badge: '=(items[props.lock_item].state == "ON") ? "Closed" : "Open"'
badgeColor: '=(items[props.lock_item].state == "ON") ? "green" : "red"'
style:
font-size: large
title: Lock
accordionItem: true
action: analyzer
actionAnalyzerItems: =[props.door_item]
badge: '=(items[props.door_item].state == "ON") ? "Closed" : "Open"'
badgeColor: '=(items[props.door_item].state == "ON") ? "green" : "red"'
style:
font-size: large
title: Doors
slots:
accordion:
for: item
fragment: true
groupItem: =props.door_item
slots:
default:
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems: =[loop.item.name]
badge: '=(items[loop.item.name].state == "ON") ? "Closed" : "Open"'
badgeColor: '=(items[loop.item.name].state == "ON") ? "green" : "red"'
icon: '=(items[loop.item.name].state == "ON") ? "door-closed" : "door-open"'
title: =loop.item.label
accordionItem: true
action: analyzer
actionAnalyzerItems: =[props.window_item]
badge: '=(items[props.window_item].state == "ON") ? "Closed" : "Open"'
badgeColor: '=(items[props.window_item].state == "ON") ? "green" : "red"'
icon: "=(items[props.window_item].state === 'ON') ? 'window-closed' : 'window-open'"
style:
font-size: large
title: Windows
slots:
accordion:
for: item
fragment: true
groupItem: =props.window_item
slots:
default:
action: analyzer
badgeColor: '=(items[loop.item.name].state == "ON") ? "gray" : "lightblue"'
icon: '=(items[loop.item.name].state == "ON") ? "window-closed" : "window-open"'
accordionItem: true
action: analyzer
badge: '=(items[props.motion_item].state == "ON") ? "Movement" : "Calm"'
badgeColor: '=(items[props.motion_item].state == "ON") ? "red" : "green"'
style:
font-size: large
title: Movement
slots:
accordion:
for: item
fragment: true
groupItem: =props.motion_item
slots:
default:
action: analyzer
badge: '=(items[loop.item.name].state == "ON") ? "Movement" : "Calm"'
badgeColor: '=(items[loop.item.name].state == "ON") ? "red" : "green"'
action: analyzer
actionAnalyzerItems: =[props.leakage_item]
badge: '=(items[props.leakage_item].state == "ON") ? "Leak" : "Dry"'
badgeColor: '=(items[props.leakage_item].state == "ON") ? "red" : "green"'
icon: "=(items[props.leakage_item].state === 'ON') ? 'f7:drop_triangle' : 'f7:drop'"
style:
font-size: large
title: Leakage
visible: "=props.leakage_item ? true : false"
action: analyzer
actionAnalyzerItems: =[props.smoke_item]
badge: '=(items[props.smoke_item].state == "ON") ? "Smoke" : "No smoke"'
badgeColor: '=(items[props.smoke_item].state == "ON") ? "red" : "green"'
icon: "=(items[props.smoke_item].state === 'ON') ? 'f7:flame_fill' : 'f7:flame'"
style:
font-size: large
title: Smoke
visible: "=props.smoke_item ? true : false"
- component: f7-tab
class:
- display-flex
style:
margin: 5px
padding: 0px
visible: =(vars.select == 5)
slots:
default:
style:
text-shadow: none
width: 100%
slots:
default:
- component: oh-chart
height: 50vh
options:
backgroundColor: rgba(0,0,0,0.5)
color:
- red
- "#01ffa6"
- yellow
- "#1689f2"
textStyle:
color: white
slots:
dataZoom:
- component: oh-chart-datazoom
type: inside
grid:
- component: oh-chart-grid
includeLabels: true
left: center
width: 60%
legend:
- component: oh-chart-legend
bottom: 1
textStyle:
type: scroll
series:
- component: oh-time-series
gridIndex: 0
type: line
xAxisIndex: 0
yAxisIndex: 0
gridIndex: 0
type: line
xAxisIndex: 0
yAxisIndex: 1
gridIndex: 0
type: line
xAxisIndex: 0
yAxisIndex: 2
gridIndex: 0
type: line
xAxisIndex: 0
yAxisIndex: 3
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
nameLocation: start
position: left
show: "=props.temp_item ? true : false"
gridIndex: 0
nameLocation: start
position: right
show: "=props.humidity_item ? true : false"
gridIndex: 0
nameLocation: start
offset: 20
position: left
show: "=props.lightlevel_item ? true : false"
gridIndex: 0
nameLocation: start
offset: 30
scale: true
show: "=props.CO_item ? true : false"
Widgets are using custom icons, so you’ll have to download them and place them to openhab’s /icons/classic directory, or change the code to your preferred icons.
