tnemrap
(Michael Parment)
November 4, 2022, 1:14pm
1
This is what i have.
and i want to center oh-icon and label on card.
Widget
uid: Simple_Status
tags: []
props:
parameters:
- description: Title of the card
label: Title
required: false
type: TEXT
- description: Name of the Icon
label: Icon
required: true
type: TEXT
- description: Color for icon active
label: Color
required: true
type: TEXT
- context: item
description: Main item
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Nov 3, 2022, 4:44:01 PM
component: f7-card
title: =(props.title)
style:
box-shadow: var(--f7-card-expandable-box-shadow)
overflow: hidden
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
- align-items-center
- justify-content-space-evenly
slots:
default:
- component: oh-icon
icon: =props.icon
width: 50%
height: 50%
color: '=items[props.item].state == "ON" ? props.color : "gray"'
- component: Label
text: =items[props.item].state
style:
text-align: center;
JustinG
(JustinG)
November 4, 2022, 3:00pm
2
If your copy-paste is true to what’s in the widget editor, then it looks like it’s primarily an issue of yaml formatting.
In f7-col
: class
is not indented under config
In f7-col
: default
is only one space, not two under slots
In f7-col
: The icon component is not indented under default
In Label
: style
YAML is finicky about these things, indentations are actually part of the syntax not just a visual convenience.
tnemrap
(Michael Parment)
November 4, 2022, 8:37pm
3
Thank you @JustinG that was the problem.
uid: State_Widget
tags: []
props:
parameters:
label: Title
required: false
type: TEXT
label: Icon
required: true
type: TEXT
label: Color
required: true
type: TEXT
- context: item
label: Item
required: false
type: TEXT
parameterGroups: []
component: f7-card
style:
overflow: hidden
slots:
default:
slots:
default:
- component: f7-col
class:
- display-flex
slots:
default:
icon: =props.icon
width: 30%
height: 30%
- component: Label
style:
text-align: center;
ysc
(Yannick Schaus)
November 4, 2022, 8:47pm
4
Also worth noting are the new operators you can use in expressions:
icon: =props.icon
width: 30%
height: 30%
color: '=@@props.item == "ON" ? props.color : "gray"'
- component: Label
text: =@props.item
style:
text-align: center
@props.item
retrieves the display state of the item given its name, or falls back to the raw state if isn’t defined - it’s (almost) equivalent to:
items[props.item].displayState || items[props.item].state
@@props.item
always retrieves the raw state of the item given its name - it’s equivalent to: items[props.item].state
