That would be amazing!!
Thanks let me know if you need help testing.
I got the binding working again with the new v4 API. I created a branch on my github if anyone wants to see the changes. I compiled a JAR file and included a google drive link below. I have successfully tested it with openHAB 1.8.3 and openHAB 2.0. All the item configuration is the same so nothing needs to be updates besides the JAR file. If you have any issues, please let me know.
Thanks for the help,
Scott
https://drive.google.com/open?id=0Bx6EpCMtJQHVVzlQSmtWT3AwWDg
Funny enough I just finished making the changes as well and posted in the Github bug/issue tracker.
The code changes are nearly identical. I can confirm it’s working.
Ok, newbie / not so newbie question, how do I get the updates running in my instance of OH2 on my PI?
You have to remove the existing MyQ binding using the PaperUI or addon.cfg depending on how you installed it. Then you have to copy the JAR file to “/usr/share/openhab2/addons” on your pi. If you are using Samba for openhab configuration, this location is normally not accessible remotely. I normally SSH into my pi, stop the openhab service, change directory to the folder mentioned before and use wget to download the binding. I have a hard time using wget with google drive links so I also uploaded the JAR to my web server here. I’ll include all the linux commands below. If you need anymore help please let me know.
sudo systemctl stop openhab2.service
sudo cd /usr/share/openhab2/addons
sudo wget http://pictures.scott-hanson.com/org.openhab.binding.myq-1.10.0-SNAPSHOT.jar
sudo systemctl start openhab2.service
great thanks! Got it working.
works perfect, you rock. Thanks!!
Thank @scooter_seh for the work and the instruction. But I still cannot connect to the server (I still use the same myq.cfg, items, sitemap as before). It’s on OH2. Below is the log. It seems like it’s using the right jar (the version number).
I also set
myq:appId=NWknvuBd7LoFHfXmKNMBcgajXtZEgKUh4V7WNzMidrpUUluDpVYVZx+xT4PCM5Kx
but it still doesn’t work.
22:11:34.564 [ERROR] [nhab.binding.myq.internal.MyqBinding] - Could not connect to MyQ service
java.io.IOException: Request Failed: Unknow resonse
at org.openhab.binding.myq.internal.MyqData.request(MyqData.java:248)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.login(MyqData.java:144)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.getSecurityToken(MyqData.java:183)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.getMyqData(MyqData.java:128)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding.poll(MyqBinding.java:210)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding.access$0(MyqBinding.java:202)[204:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding$1.run(MyqBinding.java:407)[204:org.openhab.binding.myq:1.10.0.201702210212]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.8.0_102]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)[:1.8.0_102]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)[:1.8.0_102]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)[:1.8.0_102]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.8.0_102]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1.8.0_102]
at java.lang.Thread.run(Unknown Source)[:1.8.0_102]
My setup is different from yours. I am using docker images, and extract openhab to /openhab. The jar is put in /openhab/addons. It throws the exception.
I tried to use
log:set trace openhab.binding.myq
or
log:set trace openhab.binding.myq.internal
but I don’t see any trace regarding the connection. It just shows me the error. Do you have any pointers where I should continue?
If you are running on openHAB 2, you should not be using the myq:
prefix. Did you follow the documentation here? Also, having possibly set this value in the internal configuration of your server, you might want to delete the file /var/lib/openhab2/config/org/openhab/myq.config
and restart the server.
I didn’t have the prefix myq: in my file.
At first I didn’t set it, and it didn’t work. And then I set appId, it didn’t work either. I restart the docker container. The server was restarted.
For the docker image, I download the openhab snapshot tar file and untar it to /openhab. I don’t see that it’s creating a file in /var/lib/openhab2 and I don’t see the config folder in /openhab either.
Are the changes now merged back into the official binding, or do we need to continue to use the temporary fix binding?
Now that I found the note on the update to the apt repository location, just updated so appreciate that. Thanks for all the work.
Fresh install of openhab2 on Ubuntu using apt and the new jfrog.io SNAPSHOTS. Installing the MyQ binding from PaperUI seems to load a version from February 14th (pre-fix). If I download the .jar and drop it in addons all works fine, and I can get a more recent build. Just curious how the online repository is picking which version to fetch?
Any ideas? Thanks
Thank you for your work on this! I installed the fix, but still having trouble getting it to connect. I’m using OH 2. I had it working before they changed the API, but after installing the fix I’m still getting this:
2017-03-04 14:54:13.200 [WARN ] [org.openhab.io.net.http.HttpUtil ] - Method failed: HTTP/1.1 500 Internal Server Error
2017-03-04 14:54:13.251 [ERROR] [nhab.binding.myq.internal.MyqBinding] - Could not connect to MyQ service
at org.openhab.binding.myq.internal.MyqData.request(MyqData.java:248)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.login(MyqData.java:144)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.getSecurityToken(MyqData.java:183)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqData.getMyqData(MyqData.java:128)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding.poll(MyqBinding.java:210)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding.access$0(MyqBinding.java:202)[211:org.openhab.binding.myq:1.10.0.201702210212]
at org.openhab.binding.myq.internal.MyqBinding$1.run(MyqBinding.java:407)[211:org.openhab.binding.myq:1.10.0.201702210212]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.8.0_121]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1.8.0_121]
at java.lang.Thread.run(Unknown Source)[:1.8.0_121]
and
20:09:48.059 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.SocketException: Connection reset
20:09:48.059 [ERROR] [nhab.binding.myq.internal.MyqBinding] - Could not connect to MyQ service
java.io.IOException: Null response from MyQ server
at org.openhab.binding.myq.internal.MyqData.request(MyqData.java:218)[211:org.openhab.binding.myq:1.10.0.201702210212]
Any ideas?
Can confirm the same issue. Wondering if it’s related to the new App Marketplace being deployed - Distributing bindings through the IoT Marketplace
Looking through my list of installed bindings. It appears the 2.1.0 SNAPSHOT and 0.9.0 Eclipse Smarthome bindings are getting very recent builds. All 1.10.0 bindings are stuck on the February 14th builds.
I think part of the problem is that I have a LiftMaster brand myQ gateway (and garage door opener) and this binding seems to be specific to Chamberlain. I guess I just got lucky before the API changed.
I ended up using the mios plugin on my vera edge and having openhab control that. (I know this isn’t helpful to people trying to get this binding working, but I wanted to share my work around.)
New OH2 SNAPSHOT build 838. MyQ binding updated to a March build and is working quite nicely on my LiftMaster MyQ gateway. Thanks.
