Chamberlain MyQ Binding
I am using this binding and can confirm it is working properly. Bridge was added fine, but it took an Openhab restart to discover door thing (as noted above in another post, restart became longer with binding installed). On closing, the door starts beeping and doesn’t move. I hastily pressed manual close on wall mount and it closed. Quick research shows that the beeping is normal as closing the door from a “remote source” calls for the beeping as a safety measure. So my error.
I haven’t tested lamp as my wall mount has a motion sensor to turn on light, and I have a motion sensor in the garage to turn on overhead lights. So not really needed.
