I [quote=“tebore, post:288, topic:4192”]
Anyone having the same problem?
[/quote]
Yes but min has been showing things in the logs more than today. I can say today that I was not able to open the garage door while on myopenhab, but when in the garage and on my home network I was able to close it. If that matters. Logs are loaded with:
Caused by: java.io.EOFException: HttpConnectionOverHTTP@5566aa97(l:/192.168.0.50:41938 ↔ r:myqexternal.myqdevice.com/65.166.252.145:443,closed=false)=>HttpChannelOverHTTP@4d281933(exchange=HttpExchange@3e0f16db req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@39966cac(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@3a568973{s=START}],recv=HttpReceiverOverHTTP@37bafe8b(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]<-DecryptedEndPoint@71c59f69{myqexternal.myqdevice.com/65.166.252.145:443<->/192.168.0.50:41938,OPEN,fill=-,flush=-,to=22/0}->HttpConnectionOverHTTP@5566aa97(l:/192.168.0.50:41938 ↔ r:myqexternal.myqdevice.com/65.166.252.145:443,closed=false)=>HttpChannelOverHTTP@4d281933(exchange=HttpExchange@3e0f16db req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@39966cac(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@3a568973{s=START}],recv=HttpReceiverOverHTTP@37bafe8b(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]->SocketChannelEndPoint@7bbc6ef1{myqexternal.myqdevice.com/65.166.252.145:443<->/192.168.0.50:41938,ISHUT,fill=-,flush=-,to=29/0}{io=0/0,kio=0,kro=1}->SslConnection@75af7de4{NEED_WRAP,eio=-1/-1,di=-1}=>HttpConnectionOverHTTP@5566aa97(l:/192.168.0.50:41938 ↔ r:myqexternal.myqdevice.com/65.166.252.145:443,closed=false)=>HttpChannelOverHTTP@4d281933(exchange=HttpExchange@3e0f16db req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@39966cac(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@3a568973{s=START}],recv=HttpReceiverOverHTTP@37bafe8b(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:338) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1557) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:209) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:147) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:155) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) ~[?:?]
… 1 more
2019-02-28 16:58:31.674 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.chamberlainmyq-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.chamberlainmyq [14]
Unresolved requirement: Import-Package: com.google.common.collect
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
I’m going to have to revert. Now the website won’t even come up.
Edit: reverted and put the 2.5 back again but now getting a really long thing I can’t fully copy:
2019-02-28 17:10:49.427 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while calling thing handler factory ‘org.openhab.binding.chamberlainmyq.internal.ChamberlainMyQHandlerFactory@794b5f09’: null
at org.openhab.binding.chamberlainmyq.config.ChamberlainMyQDeviceConfig.(ChamberlainMyQDeviceConfig.java:49) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQHandler.(ChamberlainMyQHandler.java:59) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQDoorOpenerHandler.(ChamberlainMyQDoorOpenerHandler.java:46) ~[?:?]
at org.openhab.binding.chamberlainmyq.internal.ChamberlainMyQHandlerFactory.createHandler(ChamberlainMyQHandlerFactory.java:54) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:128) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.doRegisterHandler(ThingManagerImpl.java:600) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerHandler(ThingManagerImpl.java:581) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:1073) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.lambda$10(ThingManagerImpl.java:1056) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:?]
at java.util.concurrent.CopyOnWriteArraySet.forEach(CopyOnWriteArraySet.java:404) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.lambda$9(ThingManagerImpl.java:1053) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184) [?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) [?:?]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) [?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) [?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) [?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151) [?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174) [?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) [?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418) [?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.handleThingHandlerFactoryAddition(ThingManagerImpl.java:1052) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.addThingHandlerFactory(ThingManagerImpl.java:1023) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1809) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
JT, that is not really great. I know every time I’ve cleared the cache my system never comes back again. Including this time, which fortunately I’m running VM and can revert to a prior snapshot. Once I clear the cache it’s like a festival of missing stuff that starts complaining in the logs.
I removed the 1.13 MyQ binding through my addons.cfg, stopped openhab 2.4, added the new 1.14 snapshot jar to the addons folder, and started up openhab back up. It worked for me after that. I still need to test the 2.5 snapshot some more. With all the github repo changes it is very hard to get 2.x building at the moment.
Using the 2.5 SS jar here.
For the most part it’s working. It even got rid of that URL error that used to come up.
The only problem I have right now is periodically my light switches will all switch from ONLINE and OFFLINE and back again. I’m not sure if this is because of the binding or because of Chamberlain’s crap infrastructure and the binding is losing connection with it.
Cleaned cache and tmp directories. When I deleted the directories, openhab would not come up. I had to make sure that the cache and tmp directories existed and empty.
Works now. No more cookie errors also. Thank you.
java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@1808f7e(l:/192.168.3.50:44220 <-> r:myqexternal.myqdevice.com/65.166.252.145:443,closed=false)[HttpChannelOverHTTP@19d82d8(exchange=HttpExchange@118fb13 req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@17d9627(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@5f1749{s=START}],recv=HttpReceiverOverHTTP@18dc098(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]]
at org.openhab.binding.chamberlainmyq.internal.HttpUtil.executeUrl(HttpUtil.java:163) [196:org.openhab.binding.chamberlainmyq:2.5.0.201902280358]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.request(ChamberlainMyQGatewayHandler.java:366) [196:org.openhab.binding.chamberlainmyq:2.5.0.201902280358]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.executeMyQCommand(ChamberlainMyQGatewayHandler.java:225) [196:org.openhab.binding.chamberlainmyq:2.5.0.201902280358]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQLightHandler.setLightState(ChamberlainMyQLightHandler.java:85) [196:org.openhab.binding.chamberlainmyq:2.5.0.201902280358]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQLightHandler.handleCommand(ChamberlainMyQLightHandler.java:71) [196:org.openhab.binding.chamberlainmyq:2.5.0.201902280358]
My logs are all clean finally. I removed this binding. The 2.x version anyway. Should I be going to the 1.14 version and manually configuring the settings in files? I have been unable to get back to the 2.x version by removing the 2.3 version and going to 2.5. If it’s working, cleaning the cache folder system never starts again.
