If you are using Docker, are you using persisted volume? If not I recommend you start there so when something happens to your container, the volume doesn’t get removed and the data doesn’t get lost. And once you have the persistent volume, you will know the path to that where you can copy the jar file for manual update.
For those who want to use it I noticed the JSoup dependency is based on 1.14. https://jsoup.org/packages/jsoup-1.14.3.jar
Dump that and the File from from the above links to the add-ons folder.
hey guys, just in the last day or so i have been getting error messages from my garage door. Both the door and the MyQ Account thing are offline. The logs from the account thing are as follows:
For me, my thing “myq account” is stuck at CONFIGURATION_ERROR
Could not login with credentials
I deleted the thing and recreated, samething. Tried the credentials at myq.com, they work. Could it be because it doesn’t handle well special character in password?
edit: Just found out I had 2 thing named MyQ Account… one of them is online… Don’t know why but disregard this message
@scooter_seh do you by chance have the latest 2.5 jar (with the v5.1 apis). I cant find it anywhere. Im still on OH2 and dont want to upgrade to OH3 due to some legacy bindings that I use and are working really well. I know its not supported, but wanted to give it a try.
Yup, definitely seen some connection bumps lately. Nothing that has interrupted any functionality but they show up in the logs. I assumed MyQ might be pushing patches or having some issue they’re trying to remediate.
Anyone having issues with this binding or is it just me? The bridge is Online and all devices are online but commands from OpenHAB to raise/lower the door don’t seem to work. It doesn’t throw any error and looks like it’s working, but the door doesn’t raise or lower.
I just tested mine and they are working fine but I’m running a snapshot binding (org.openhab.binding.myq-3.4.0-SNAPSHOT.jar) as I was having the JsonSyntaxException error.
I guess make sure you can control the doors from the myq app directly.
I realized last night that I was no longer able to control the door from the MyQ app either, however, I was still getting notifications from the app when I manually opened/closed the door and was seeing sensor updates in the app. I guess the garage door motor had stopped responding to the MyQ hub’s commands, like it unlearned the hub’s code(s). From what I can tell, there’s no way to reset just this particular issue. I had to factory reset MyQ, remove the device and go through the initial setup process again. It’s all working now. Very strange.
