I’m fairly new to OH2 but recently moved my home over from Vera. one of the features I’m trying to add, is a text item in my sitemap that would include the last successful check to MyQ. Not sure what’s going on with my binding, but it is having problems on & off, logging items like this:
$Path=/; $Domain=.myqexternal.myqdevice.com". Illegal domain attribute “.myqexternal.myqdevice.com”. Domain of origin: “myqexternal.myqdevice.com”
2019-01-23 10:11:18.742 [ERROR] [nhab.binding.myq.internal.MyqBinding] - Could not connect to MyQ service
I’m not sure if this is actually service impacting yet, but I was hoping to see when it last successfully checked in with the service. Any ideas if that’s possible?
edit for what it’s worth, I have the 828LM. The OpenHab app on my phone seems to work correctly for opening & closing, but when I use the garage door remotes, the app does not ever update - I’ve left it for over an hour as a test. Perhaps there is something else missing or incorrect. I am controlling 2 doors with the 828LM and both work correctly when only used with the OpenHab App.
Ok, I think I have this figured out. My problem was that the MyQ addon in 2.4 was pulling the addon version 1.13.0something. I found this post
which mentioned there was a newer version. I grabbed that JAR file, put it in /usr/share/openhab2/addons restarted my openhab2 service, went to inbox & I added the MyQ gateway (in my case the 828LM) which wanted my log in info for Chamberlain. Once that was in, I inboxed added again & bam, both of my garage doors showed up.
I then added an items file for them with this contents:
Switch item=Garage1State
Text item=Garage1Status
Switch item=Garage2State
Text item=Garage2Status
It’s all looking good!
The version 1.13 binding did pull things like the serial number and other random facts, but it wasn’t checking in w/ their service properly, even though it could control the door. The new version is working great, door status updates when done manually via an opener now too.
I posted a bundle here in hopes someone else may find this and use the info!
