I am new to this openHab. I have a Chameleon called smart home system at home. This has an HTTPS REST API, where I can read all the items on the network and even controll them. The data is in JSON format.
I want to create a dedicated plugin for this hardware. My question is where can I start, do you know any similar plugin which is work the same way(or closely to this)?
On Chameleon site you need to enable REST API.
The GUID on the authorization line is the API key from the REST API config.
At the Channels you must use the RegisterNumber (/91 /46) not the SerialId from Chameleon.
