I want that the color of the cell is changed when the state of my jablotron system is armed or disarmed.
for now i am only able to have the label changed to armed or disarmed.
You can find the yaml code that i use.
You would do something like the following:
component: oh-cell
color: '=(items.GPSMarkatHome.state === "ON") ? "green" :
(items.GPSRileyatHome.state === "OFF") ? "green" :
(items.GPSEthanatHome.state === "OFF") ? "green" : "red"'
on: true
title: Presence
slots:
default:
PS. Please use code fences - makes it easier to see what you are doing
I have a similar problem with an item that returns “true” or “false” and I want to change the colour of a cell depending on this. But configuring it in the widget itself with
=(items.VectorF2U7_VectorF2U7_Docked.state == “true”) does not work. It doesn’t seem to work in YAML itself either, what am I doing wrong?
component: oh-cell
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems:
- VectorF2U7_VectorF2U7_Battery
color: '=(items.VectorF2U7_VectorF2U7_Docked.state === "true") ? "green" : "red"'
header: Vector Battery
icon: material:smart_toy
subtitle: '="Docked: " + (items.VectorF2U7_VectorF2U7_Docked.state)'
title: =(items.VectorF2U7_VectorF2U7_Battery.displayState)
trendGradient:
- "#E64A19"
trendItem: VectorF2U7_VectorF2U7_Battery
Try remove your trend settings? I seem to recall something about not being able to use both together?
EDIT: You need to add: on: true
to the oh-cell config block:
component: oh-cell
on: true
action: analyzer
ah, ok thank you! If I remove the trend, it works.
