I seem to have a simple problem around icon colors, which I can’t seem to solve
I’m using iconify icons, choosing the icon and icon-color through state-dependant choices…
value: ""
icon: ={ON:'if:mdi:lamps',OFF:'if:mdi:lamps-outline'}[@'Suite1_BedsideLamps_Switch']
iconColor: ={ON:'gold',OFF:'#bbb'}[@'Suite1_BedsideLamps_Switch']
color: yellow
This works well for me.
I tried to the same thing with locally stored (openhab-conf/icons/classic) icons (in svg format). while the icon choice expression works, the iconColor choice doesn’t work. The iconColor would always stay black:
value: ""
icon: ={ON:'if:mdi:lamps',OFF:'ceilinglamp'}[@'Suite1_BedsideLamps_Switch']
iconColor: ={ON:'green',OFF:'red'}[@'Suite1_BedsideLamps_Switch']
color: yellow
I looked into the svg file, which I downloaded from iconify and stored locally:
<svg xmlns="http://www.w3.org/2000/svg" width="24" height="24" viewBox="0 0 24 24">
<path fill="currentColor" d="M8 9h3V4h2v5h3l4 8H4zm6 9a2 2 0 0 1-2 2a2 2 0 0 1-2-2z"/>
</svg>
I believe, I read somewhere that the color was set through the fill attribute set to currentColor …, which is the case.
So any hint on how I can get locally stored svg icon react to the change of the iconColor attribute?
(obviously the example given here is for illustrative purposes and doesn’t make much sense … what I’d actually like to do is to a few additional mdi-style icons for consistency, in order to extend the already very helpful mdi-iconset. And I would like the icons to react similarly as the iconify:mdi iconset stored online, without having to hardcode the iconColor in the locally stored extensions.
I have read about restrictions for openhab icons … would they apply to all “locally stored” icons … which would explain the behavior. But still that doesn’t provide a solution.
