@Schrott.Micha (or anyone)
RPi 4
Raspbian initial load, followed by Openhabian install
8G USB thumbdrive, exfat
I just tried your above recommendation, after copying my existing event and openhab logs over for appending purpose, and setting the USB thumbdrive directory permissions to rw for owner, group and others. The OPENHAB_LOGDIR now points to a directory on the thumbdrive;
logdir=/media/pi/EMTEC/openhablogs
When I check the status (systemctl status openhab2.service) I’m getting the following;
Jan 19 14:52:24 raspberrypi karaf[17392]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Null object returned for RollingRandomAccessFile in Appenders. Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
Jan 19 14:52:24 raspberrypi karaf[17392]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “LOGFILE” for logger config “root” Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
Jan 19 14:52:24 raspberrypi karaf[17392]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “AUDIT” for logger config “org.apache.karaf.jaas.modules.audit” Ignored FQCN: org.apache.logging.log4j.spi.Abst
Jan 19 14:52:24 raspberrypi karaf[17392]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “EVENT” for logger config “smarthome.event” Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
Now none of the logs are being updated anywhere.
Have I missed a step somewhere?
