I have been using OpenHAB on Openhabian for a while and last year transferred to an Unraid docker. All was going well until I needed to run another docker that also uses ports 8080 and 8443.
The unraid docker interface is a bit clunky, I am a docker novice, so I cannot find a way to forward different ports into the OpenHAB docker container or change OpenHAB to look at different ports.
Thanks.
Unraid uses a custom UI by default to configure docker containers. Haven’t figured out how to run them from the commandline and configure them to auto-start.
I have got round the issue by setting a few of my containers to use custom IPs, that way I can leave OpenHAB with the defaults and it just works, and I don’t have to change ports on anything.
