Hi all,
sorry for this newbie question but I just started with HabPanel. In my dashboard nearly all text is in #0db9f0 color but I used the clock widget and the text is white. Where can I change it to my standard color?
Stephen
Hi all,
Stephen
Find the class that the widget uses and override it with {color:xxx}
. There’s a setting where you can use your own css file.
Thanks, but this is exactly my problem. I only found /var/lib/openhab2/config/org/openhab/habpanel.config. I changed here the font size for testing, but after reboot it was overwritten with the old value. Does anyone know where the right file is?
