Change in UI "Add Equipment to Model": Prefix changes "on the fly"
running OH5.0.1 on docker.
nor sure, if this came with 5.0 oder with 5.0.1, but personally I find it annoying, that a change in theGroup Name for the items is changed “on the fly”. What do I mean?
My use case is as follows:
  1. adding a new thing with a bunch of channels.
  2. save some time by “adding equipment to model”
  3. change the Group Name to some short stuff, because I do have loads of items and I want short prefixes to have a quick overview to what device the item belongs
  4. click “select all” (or at least more than a handful)
  5. rename the Group Name to a longer name, because I want the group name to be more than a short prefix
so now ALL(!) the items get that new prefix plus the channel names. Before it was easy: the prefix was pulled from the group name only with the “select” action. now - and that’s annoying! - the group name has a live trigger to the prefix.
Is there some really good reason for that? So, now I do have two options left (both time consuming):
  1. create the group with the short prefix, then create another group with my desired name and move all items to the new group, delete the short name group after
  2. iterate manually through each and every item in the “select” list and change manually the prefix to the desired short version.
both are very annoying. :wink:
