Hello OH-enthusiasts,
I’d like to change some parameters on an item which was defined by the paperUI.
If I try to enter the changes in the jsondb file they are deleted after a reboot of OH2.
So what is the correct way to change it?
Thank you!
Thank you!
It seems like this should work. What happens if you edit the file with OH not running and then start?
