is there a possibility to change the background image of a location tile by a rule?
If yes, could someone provide an example?
Hi there,
I am not sure.
One hacky idea would be to use executeCommandLine
in the rule an then execute a script that replaces the image on your disk with another image…
executeCommandLine("path/to/my/script.sh")
the script could look like this:
cp -f [oringinal file] [new file]
Copies the original file and overwrites the target file (hence -f
which stands for “force”).
I dont know if this works… but you could try.
