rkleinert
(Robert Kleinert)
1
Hi guys,
I have a milight warmwhite / coldwhite led bulb and wrote a rule to change the temperature to warm and reduce the brightness in the evening.
But this only works, when the bulb is switched on at that exact time.
Is there a solution to change the color when it is switched off, as milight saves the current state?
Thanks!
Robert
rkleinert
(Robert Kleinert)
3
Hm ok. And is it possible to recognize when the light is switched on with a regular switch?
hmerk
(Hans-Jörg Merk)
4
If you mean the original remote, that is not possible, cause there is only one way communication, no feedback from the led bulbs.
