When i try to change the default ports for 8080 dan 8443 to 80 an 443 via
/etc/default/openhab
the MainUI does not load any more. This is since update from 3.0.1 to 3.1
Can someone help me?
The file /etc/default/openhab contains the values as you configured them or have they been overwritten by upgrade to 3.1.0 ?
What ports are shown to be in use when you run the command
sudo netstat -tulpn | grep java
Yes the file /etc/default/openhab still contains the values i configured but
tcp6 0 0 127.0.0.1:8101 :::* LISTEN 6696/java
tcp6 0 0 :::5007 :::* LISTEN 6696/java
tcp6 0 0 127.0.0.1:40495 :::* LISTEN 6696/java
udp6 0 0 :::1900 :::* 6696/java
udp6 0 0 192.168.0.67:37244 :::* 6696/java
udp6 0 0 192.168.0.67:60934 :::* 6696/java
udp6 0 0 :::5353 :::* 6696/java
does not show 80 oder 443. When i change the ports back to default
tcp6 0 0 127.0.0.1:8101 :::* LISTEN 5255/java
tcp6 0 0 127.0.0.1:41543 :::* LISTEN 5255/java
tcp6 0 0 :::5007 :::* LISTEN 5255/java
tcp6 0 0 :::8080 :::* LISTEN 5255/java
tcp6 0 0 :::8443 :::* LISTEN 5255/java
udp6 0 0 :::1900 :::* 5255/java
udp6 0 0 192.168.0.67:51649 :::* 5255/java
udp6 0 0 192.168.0.67:60603 :::* 5255/java
udp6 0 0 :::5353 :::* 5255/java
i can find 8080 an 8443. So i have no idea whats going wrong
Is there any other service on the host that uses ports 80, 443 ?
Is there any entry in /var/log/openhab/openhab.log that gives a hint about the problem ?
What about
sudo journalctl
does that give any hint ?
That seem to be the right way. Look what i found in openhab.log
2021-06-30 21:23:48.732 [ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
org.eclipse.jetty.util.MultiException: Multiple exceptions
at org.eclipse.jetty.util.MultiException.ifExceptionThrow(MultiException.java:122) ~[?:?]
at org.eclipse.jetty.server.Server.doStart(Server.java:413) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl$1.start(JettyServerImpl.java:350) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:255) [bundleFile:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:226) [bundleFile:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:210) [bundleFile:?]
at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerServlet(HttpServiceProxy.java:69) [bundleFile:?]
at org.openhab.core.io.http.servlet.BaseOpenHABServlet.activate(BaseOpenHABServlet.java:56) [bundleFile:?]
at org.openhab.core.io.http.servlet.OpenHABServlet.activate(OpenHABServlet.java:40) [bundleFile:?]
at org.openhab.core.ui.internal.chart.ChartServlet.activate(ChartServlet.java:121) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:244) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:685) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:529) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:318) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:354) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:776) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
Suppressed: java.io.IOException: Failed to bind to /0.0.0.0:443
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:349) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:310) ~[?:?]
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:234) ~[?:?]
at org.eclipse.jetty.server.Server.doStart(Server.java:401) ~[?:?]
Caused by: java.net.SocketException: Permission denied
at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:455) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:447) ~[?:?]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:227) ~[?:?]
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:80) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:344) ~[?:?]
... 61 more
Suppressed: java.io.IOException: Failed to bind to /0.0.0.0:80
... 61 more
And many more. similar to this.
But nothing running on port 80 or 443
Ports 80 and 443 (any port below 1024) are privileged, and are only accessible with root
. openHAB as a service does not have root privileges so does not get permission to start.
It you want to use port 80 or 443 (presumably because you don’t want to have to specify the port), you should use a reverse proxy (which has these permissions) to forward traffic on these ports to 8080, 8443 or a port higher than 1024.
But this worked for until did the update!?
I have an other problem since the update. Neither the MainUI does show any values, nor the icons update to the state of the item
But the values are there an get persisted. So this only seems to be a FrontEnd Problem
was thinking exactly about that but as the OP wrote it was working before I was not sure.
Did you try to clear the browser cache resp. try to use shift+reload ?
Is there any error message in the browser console ?
I understand that it does not always make sense to clear OHs cache - it might be a last resort to check if that helps.
Yes it definitly worked with 3.0.1.
Yes i already cleared the cache. The problem appears there and then. At the moment it is not reconstructable for me, what leads to the problem. I tried it with an emptied cache, with different browers, local and via myopenhab.org.
Nothing has changed from the Linux package side, but I’m pretty sure permissions to use the port is the cause. Did you do anything previously to give openHAB or Java these permissions? Either by changing the user that runs the service or by using a setcap
command on Java?
No i did not do anything. Anyway, i can live with 8443, I just thought this problem may be related to the other one i posted in post 7
