Change rrd4j policy for 2 databases
Do have a running setup with a few databases. I am fine with persistence strategy for most databases. But for 2 of them I want to have something else. I need better time resolution for the first 12h (instead of just 1 hour). I read about
but I don’t get it really. The problem: For the default there are no files at all, so nothing easily to modify.
As far as I understand I don’t need a rrd4j.persist file, but one services/rrd4j.cfg. But where to store that? The location for rrd4j.persist is described, but not for that services folder…
So can you help me what is needed to extend the 10s resolution to 12h for a database named:
/persistence/rrd4j/sm_consumption.rrd ?
Can this modification be done in Web-IF or in console?
What happens with already existing data? Probably a new file will be created and old stuff is not valid anymore?
According to the docs the default resolutions are:
It defines 5 archives:
granularity of 10s for the last hour
granularity of 1m for the last week
granularity of 15m for the last year
granularity of 1h for the last 5 years
granularity of 1d for the last 10 years
So IIUC you want to introduce a new datasource for 12h with a granularity of 10s.
No but there are many examples in the docs you linked to as well as an explanation of each of the fields and the math you’ll need to do to figure out the proper values to enter for each field. But having an example is going to have limited value for you because rrd4j is pretty arcane and all the properties interact with each other. You kind of have to be knowledgable in rrd4j internals to use the examples anyway.
But the defaults are in the docs:
default_numeric.def=GAUGE,600,U,U,10
default_numeric.archives=LAST,0.5,1,360:LAST,0.5,6,10080:LAST,0.5,90,36500:LAST,0.5,360,43800:LAST,0.5,8640,3650
That doesn’t use the last line because it applies to all Items that are not otherwise listed elsewhere in an rrd4j.cfg file.
Doesn’t really help much to have the example, does it.
Under the services folder in $OH_CONF. Where is $OH_CONF? Depends on how you installed OH. There is a table in the installation instructions explaining where each important folder is. For Linux see openHAB on Linux | openHAB. You already know where to put this because the .persist file is $OH_CONF/persistence/rrd4j.persist.
No
It will almost certainly become corrupted for that Item (note that custom datasource definitions get applied to individual Items, not across all of your Items).
I’ve never tried to move from the default datasources in rrd4j. But based on the docs I’d expect it to look something like the following:
my12h.def=GAUGE,600,U,U,10
my12h.archives=LAST,0.5,1,4320:LAST,0.5,6,10080:LAST,0.5,90,36500:LAST,0.5,360,43800:LAST,0.5,8640,3650
my12h.items=Item1,Item2
The above datasource has two changes from the default (see above).
The first archive has been expanded to 12 hours by increasing the ` field (archive time = sampleInterval * samplePerBox * boxCount). Multiplying the box count by 12 increases the first archive to cover the first 12 hours instead of the first hour. You could multiply any of the fields by 12 and get the same result, but I’m not sure what the implications are to changing the sampleInterval or samplePerBox on the down stream compression.
The second change is the addition of the my12h.items line. You have to list the names of the Items individually that will use this datasource instead of the default. Put those three lines in under $OH_CONF/services/rrd4j.cfg.
Thank you - think I almost understand. But I am confused about what <dsName> is and whats than a <dsName>.item ?
My item is sm_consumption
/etc/openhab/services/rrd4j.cfg :
sm_consumption.def=GAUGE,10,0,U,10
sm_consumption.archives=AVERAGE,0.5,1,4320:AVERAGE,0.5,6,10080
according to my undertstanding this saves an value every 10s (4320x) = 43200s=12h, and for a week every 1min (6*10s)*10080.
Right?
Mhh, reading a third time this dsName seems free to chose but I have to add
sm_consumption.items=sm_consumption
It’s what ever you want it to be. It’s what tells rrd4j that these three lines of config go together. It’s just a unique identifier. That’s why I used “foo12h” above. It just doesn’t matter so long as the three config lines match.
From the docs:
List of Items whose values shall be sampled and stored in the archive. The format is Item1,Item2 Note: the same Item is not allowed to be listed in more than one datasource!
I don’t know how to reword it to be more clear. You need to list the Items that are to use this datasource on that line. Above I just used “Item1,Item2” because I don’t know how many Items you want to change and what they are called.
Use code fences.
code goes here
I think so. As documented
The time span covered by a full archive is therefore (<sampleInterval> x <samplesPerBox> x <boxCount> ) seconds.
so you have 10 * 1 * 4320 = 43200.
I’ll sate it again, I don’t know the implecations of changing the samplePerBox so there might be side effects to changing that.
But what about the rest of the archives? You don’t inherit the defaults as I understand it. You need to provide archives for year, 5 years and 10 years or I expect your files will be huge.
My understanding was that (if this both archives - every 10s and every min) is full, so after 1 week, old data will be overwritten. That is ok for this example, but I might change that, true.
I have changed the default_numeric archive but this only affected the items that are created virtually or are bound to things and items in the the “item” folder. But I use two addons (for TPLink Tapo for example) these are not affected by the default archive strategy. But Im not able to find any configuration file that even mentions those items (and I have deleted the rrd files of course).
ChatGPT is clueless too, even though its of extremely valuable help in this regard.
Any idea where those items are getting the archive config from?
should I open a new thread for that question?
I also found out that the graphs dont use the new values as well. Is there another setting that must be done so that the graph will also use the increased size of the archives?
I’ve never adjusted the rrd4j policies from the default so I don’t know anything about that beyond the docs which I assume you already read. But charting, rules, the API all use the same interface to all the databases. If what you are expecting to see isn’t coming up in your charts, it’s because the data simply isn’t there.
In general, it’s always better to open a new thread than reopen an old one.
I actuall did open a new thread :X
looks like Im the only one who ever attempted that. Is there anyone who cold know more?
@opus was our resident rrd4j expert but he hasn’t been active on the forum for quite some time.
I have openhab 5.1.1 running on docker.
My goal were slightly larger bucket lists for 10s and 1 min granularity.
I placed the following rrd4j.cfg file into the directory
\openhab_conf\services:
test.def=GAUGE,1200,U,U,10
test.archives=LAST,0.5,1,4320:LAST,0.5,6,50400:LAST,0.5,90,36500:LAST,0.5,360,43800:LAST,0.5,8640,3650
test.items="SH3EM_Gesamt_Test"
I stopped openhab, deleteted the file SH3EM_Leistung_Test.rdd in \openhab_userdata\persistence, restarted openhab.
When SH3EM_Gesamt_Test was updated the file SH3EM_Leistung_Test.rdd was created, but it has the same size as all the other numeric items.
I was expecting a larger file size.
Did I place the file in the wrong directory?
( Putting it into openHAB-conf\persistence didn’t work either).
Is the default persistence configuration applied to my item before the new configuration file is found?
Put the rrd4j add-on into debug logging. You should find the answers to some of these questions there in the logs (e.g. when/if the config file is loaded.
As for the size of the files, I don’t know rrd4j well enough to comment on whether the size of the file should have changed or not.
Thanks for pointing me to the debug option. I added
ctr24h.archives=AVERAGE,0.5,1,480:AVERAGE,0.5,10,144
ctr24h.def=COUNTER,900,0,U,60
ctr24h.items=PW_Solar
test.archives=AVERAGE,0.5,1,4320:LAST,0.5,6,50400:LAST,0.5,90,36500:AVERAGE,0.5,360,43800:AVERAGE,0.5,8640,3650
test.items=SH3EM_Leistung_Test
to rrd4j.cfg in \openhab_conf\services.
Then I deleted the rrd-files of PW_Solar and SH3EM_Leistung_Test in
\openHAB-userdata\persistence\rrd4
and stopped openhab.
New rrd-files were generated when I started openhab. They have a different file size from items with the default configuration:
default: 738 kB
cr24h: 6 kB
test: 1065 kB
The file rrd4j.config in
\openhab_userdata\config\org\openhab
seems to be generated by openhab during the starting process. The lines from above are added with enclosing “:
:org.apache.felix.configadmin.revision:=L"1"
ctr24h.archives=“AVERAGE,0.5,1,480:AVERAGE,0.5,10,144”
ctr24h.def=“COUNTER,900,0,U,60”
ctr24h.items=“PW_Solar”
service.pid=“org.openhab.rrd4j”
test.archives=“AVERAGE,0.5,1,4320:LAST,0.5,6,50400:LAST,0.5,90,36500:AVERAGE,0.5,360,43800:AVERAGE,0.5,8640,3650”
test.def=“GAUGE,1200,U,U,10”
test.items=“SH3EM_Leistung_Test”
The mentioned directories are valid for openhab running in docker.
