Change switch with mouse has an effect, moving it per rest call not?
  • Platform information:
    • Hardware: INTEL Atom C2538, 16 GB Ram
    • OS: Synology DSM 6.2.4-25556 Update 2
    • Java Runtime Environment: openjdk version “14.0.2” 2020-07-14
    • openHAB version: 3.1.0
  • Issue of the topic:
    I have created a Switch that is realted to the Denon / Marrantz binding. When I move the switch per mouse on the OpenHab webinterface, the receiver is turned ON and OFF as it should be. When I use the call of the REST Api and trigger it over a REST Tool (Postman), the swtich moves, but the receiver (reproducable) doesn’t turn on.
What API endpoint are you calling? Do you get any lines in events.log saying the Item received a command?
try press F5…
Firefox?
I’m calling
http://myserver:8080/rest/items/DenonMarantzAVR_Power/state
When I do this over the webinterface, the log says:
grafik
When I do this over Postman, the log says:
grafik
The switch in the webinterface turns on in both cases…
Christoph
That just updates the internal state in openhab, and the binding doesn’t get any info on this. To send a command to the item (which gets sent to the binding) you need to send a POST request to http://myserver:8080/rest/items/DenonMarantzAVR_Power. This is what the web UI does.
That helped me - thank you very much!
Regards
