Several weeks ago I took the plunge and updated my OH2.5 installation to OH3, and apart from some issues with migrating CalDAV to iCalendar, most of that seems to have gone well. However, I notice there are two problems with OH3 in regard to its handling of persistence data (the data is definitely being stored in influxDB as it should be, because I still get good quality graphs out of that with Grafana).
The first minor annoyance is that all the persisted Switches no longer graph in the BasicUI view. I have the following in my sitemap, and the first and last graphs still work as they used to, while the middle two give me flat lines with no data:
Frame label="Graphs" {
Chart item=gTemperatures period=D refresh=60000
Chart item=gPresence period=D refresh=60000
Chart item=gClimate period=D refresh=60000
Chart item=elecDemand period=D refresh=60000
The first and last graphs are groups of Number items, but the middle two are groups of Switch items. They used to graph perfectly well (just ranging from 0 to 1 and back again), but they no longer do so.
However, the really important bit is that the persistence queries in my rules which control the watering system no longer work: changedSince(xxx) queries now always return false, regardless of whether that value has changed in the applicable period. I have updated the date/time syntax for OH3 rules, and that all looks to be working perfectly on the persistence queries for Number items, but once again my problem is with persistence queries on the Switch items. As in the cases above, my Grafana graphs show that the data is being stored correctly - those graphs still look exactly the same as they used to - so it is OH3 that is failing to correctly retrieve/use the persisted data.
Here is the start of the rule where the problem is critical:
rule "morning watering"
Item TimeOfDay changed from "Night" to "Twilight"
val averageHumidity = Outside_Humidity.averageSince(now.minusDays(1)) as Number
val averageTemperature = Outside_Temperature.averageSince(now.minusDays(1)) as Number
val thisTimeYesterdayRainfall = Rainfall.historicState(now.minusDays(1)).state as Number
val endOfYesterdayRainfall = Rainfall.historicState(now.with(LocalTime.of(0,0,0,0)).minusMinutes(1)).state as Number
val nowRainfall = Rainfall.state as Number
val wateredVeggiesLawnYesterday = waterVeggiesLawn.changedSince(now.minusHours(25))
val wateredVeggiesLawnPast2Days = waterVeggiesLawn.changedSince(now.minusHours(49))
val wateredGardenBedsYesterday = waterGardenBeds.changedSince(now.minusHours(25))
val wateredGardenBedsPast2Days = waterGardenBeds.changedSince(now.minusHours(49))
val wateredGardenBedsPast3Days = waterGardenBeds.changedSince(now.minusHours(73))
All of the persistence queries of Number items appear to work perfectly - the calculations which use the first five values have no problems at all (using historicState and averageSince queries). However, the changedSince queries (which are referring to the persistence of Switch item states) always return false, despite the fact that they definitely have changed within the applicable times.
I thought I went through all the breaking changes in the OH3 notes, but I don’t remember seeing this, and I’m really struggling to figure out how to either fix or work around it. It seems ridiculous to create and persist an extra set of variables as numbers to mirror the states just because it isn’t retrieving Switch state data properly any more. Suggestions welcome!
