I’m working with openhab 3 on a raspberry pi 3 and a conbee 2 stick. Got everything set up more or less the way I want it. I’ve now been getting started with some scripts, but progress is painfully slow.
Current Problem: I’m trying to change the brightness of my tradfri lamps via a script (aim is to emulate a sunset & sunrise). I’ve figured out how to change the color and saturation. Whenever I adjust the brightness parameter the lights flicker once but don’t change the brightness. Brightness control from the UI via the slider as well as via the remote work fine. I can see in the logs, that the commands being sent to the lights via the script are no different to those appearing when the remote/ UI is used. On the remote I have to hold down the brightness control button for a while though.
My script so far:
lightState = itemRegistry.getItem(‘CouchLightColor_Color’).getState().toString().split(‘,’);
hue = parseInt(lightState[0]);
saturation = parseInt(lightState[1]);
brightness = parseInt(lightState[2]);
if (saturation < 100 && brightness == 100){
saturation = saturation +1;
else{
if (brightness > 0){
brightness = brightness -1;
newState = hue.toString() + ‘,’ + saturation.toString() + ‘,’ + brightness.toString()
events.sendCommand(‘CouchLightColor_Color’, newState);
The script is meant to start from a known light state that it has during the day, then it’s called at regular intervals via a cron rule in the evenings to start changing the saturation and then the brightness.
If anyone could shed some light on this for me I’d be very grateful!
