I’ve seen this problem a couple of times now, consistently enough to be convinced that it isn’t an ID-10-T problem.
If I have a Group and assign multiple Items to that Group everything is fine.
However, if I subsequently remove an Item from that Group in the Items file, openHAB does not remove the Item from the Group until I restart openHAB.
I first saw the problem in a rule but it is also easy to see the problem in the Sitemap if using a Group element.
I’m posting this here to see if anyone else has seen this behavior. I’m thinking this is an ESH issue so will post over there and/or create an issue if it seems warranted.
EDIT: Apparently the Items remain a member of the Group even after a restart. More to follow if I figure out a work around…
EDIT 2: OK, the work around is to comment out the Group, save the file, uncomment the Group, save the file, and restart OH.
