Changing item/text colors in buttons
I’d like different icon/text-colors depending on whether the button is clicked or not.
Must have something to do with: iconColor: ‘=(openWBVerbindung_openWB_LP1_lademodus.state === “0”) ? “blue” :
“grey”’
I tried “==” instead of “===” and also without “.state” but neither worked. Probably quite simple, but since I’m rather new to this, I don’t find the solution …
    - component: oh-button
        class:
          - margin
          - display-flex
          - flex-direction-column
        action: command
        actionItem: openWBVerbindung_openWB_LP1_lademodus
        actionCommand: ="0"
        icon-f7: arrow_2_circlepath
        iconColor: '=(openWBVerbindung_openWB_LP1_lademodus.state === "0") ? "blue" :
          "grey"'
        text: Sofortladen
        textColor: '=(openWBVerbindung_openWB_LP1_lademodus.state === "0") ? "blue" :
          "gray"'
See Building Pages - Components & Widgets | openHAB.
You can and should experiment with expressions in the expression tester in the developer sidebar.
Notice how the Item’s state is referenced.
Thank you. Didn’t know about the developers side bar, that’s quite useful, too-
