Channel missing in Shelly thing
On OH 4.2.1 (binding 4.2.1), i have 3 Shelly Plus 2 PM devices (all 1.4.2). One of them is missing the Roller Position channel.
How to fix ?
(already removed and added again).
Did you calibrate the device ?
yes, did a reset, thus no.
Thanks.
Calibrate is not reset.
Start calibration from Shelly’s web interface.
I know. When you reset to factory default, the device has status “not calibrated”.
So, in answer to Hans-Jörgs question in full : Yes, I did calibrate, but then I did a reset of the device, thus no, the device is not calibrated (anymore).
For completeness : I had to remove and add the thing before the Roller position channel showed (or I wasn’t patient enough).
