I noticed a difference in the channel syntax of a thing which is bound to a bridge wether it is created via PaperUI or via file.
Via PaperUi the syntax is:BindingName:ThingTypeID:ThingID:Channel
The same for a file created thing: BindingName:ThingTypeID:BridgeID:ThingID:Channel
Is this intended?
Shouldn’t that be noted somewhere in the docs? (I didn’t find it so far.)
I have checked that for the Tankerkoenig and the new MQTT Binding.
It is easily reproduced by creating things via file and via PaperUI, the required channel is always shown on PaperUI.
Additional findings as pointed out by @yozik04 on this Github Thread,
the above mentioned different syntax can only be found if the device thing is created with the syntax
Thing topic mything
if created with
Thing mqtt:topic:mything
the channel syntax is the same as if all are created via PaperUI.
I am sort of lost in the middle!
What will happen in case more then one broker is used? I do not see how the used broker is determined if the later syntax is used!
I think there should be only one valid format that would produce same results as via Paper UI. If there will be many formats that would lead to bugs and misunderstandings. I’ve spent quite a lot of time to figure out why events were not triggering or my items did not appear on Paper UI.
I have closed the PR for the MQTT binding ReadMe. The ReadMe has been changed otherwise.
However I think the topic of the different syntax howto define a thing in a things-file (with or without “:”) should be discussed about. I’m not sure on which part of the openhab or eclipse github that should take place!
