zynex
(Michael Rydén)
November 6, 2018, 10:27am
#1
Hi.
I have been trying out OpenHAB2 for a while, and got most stuff working really good. But one thing I can’t figure out, channel linking for NodOn Wall Switch. When pairing them to my system, everything seems to work. But after i configured the setup and saved it, channels get unlinked after I push any of it’s buttons. It doesn’t show in Paper UI, but I can see it in Habmin. When I try linking the channels again, they stay linked until I push the button.
This means that I can’t get the id of what button I push. I have tried unpaired the unit and repaired it again, but the same thing happens when I try configure the device. I installed Domoticz last week, and everything works fine there.
There should be two channels for this switch, one nodeXX:scene_number and one nodeXX:battery_level. Neither gets linked, except for the initial initialization.
I’m using OpenHAB 2.4.0 snapshot release on a Arch installation om a RPi 3 (Arch is faster than Rasbian IMO).
Any idea for this behavior?
Dim
(Angelos)
November 6, 2018, 10:37am
#2
I can’t find this device on https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devices
does it get properly initialized with the Z-Wave binding?
do you get an xml file in /var/lib/openhab2/zwave/
folder?
which OH2.4 Snapshot # build are you running?
zynex
(Michael Rydén)
November 6, 2018, 12:01pm
#3
Yep, it got initialized as it should. It acually works until I try configuring it (LED behavior, scene mode and stuff like that). After that the channels keeps unlinking. I have a xml for it (got four of them paired).
[EDIT] Removed the wrong XML. Right one posted below.
That name of it is NodON CWS-3101 Wall Switch. I couldn’t find it in the database either, which is a bit odd. I just upgraded to the last snapshot (Build #1413 ).
I don’t think this have something to do with OZW itself, because it works flawlessly in Domoticz (except that Domoticz add a item for each button type like press, double press, hold etc… 16 items for one device altogether).
This is the device itself https://nodon.fr/en/nodon/the-z-wave-wall-switch . Also have NodOn Octan Remote (basically the same thing).
– Mike
Dim
(Angelos)
November 6, 2018, 12:20pm
#4
Can you try to add it to the DB?
zynex
(Michael Rydén)
November 6, 2018, 5:35pm
#5
Not sure how to do that, pretty new to OpenHAB. Used Domoticz a lot before, but it had it’s issues I couldn’t get over. Isn’t it in some database if OpenHAB finds it?
Dim
(Angelos)
November 6, 2018, 5:40pm
#6
How does it appear in PaperUI?
Is it recognized with a certain name? (can you post a screenshot of the thing an it’s channels?)
zynex
(Michael Rydén)
November 6, 2018, 5:48pm
#7
To get all of the page I created a PDF for you. It’s from the Ocan Remote controller.
https://michaelryden.se/index.php/s/wWKW9etcq4YbknM
zynex
(Michael Rydén)
November 8, 2018, 8:32am
#8
Did you figure something out from the pdf, or you need some additional info abut it?
Dim
(Angelos)
November 8, 2018, 8:39am
#9
I will try to add this device in Chris’ database
If successful, it will be included in the next Z-Wave binding release and you can try again then (this could take a few days)
Dim
(Angelos)
November 8, 2018, 9:05am
#10
I tried to add it (by uploading the xml) and I was presented with a message that this device is already listed as: CBCC Domotique SAS, SW-NOD-1
Message
SELECT * FROM `joo_zwave_devices` WHERE `type_id` LIKE '%0100:0100%' AND `manufacturer` LIKE '44' AND ((`versionmin`<=1.082 OR `versionmin`=0) and (`versionmax`>=1.082 OR `versionmax`=255.255))
Warning
Device with these IDs is already in the database as CBCC Domotique SAS, SW-NOD-1 and endpoints are already defined.
So I updated the existing info on https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/236
I hope that I did ok… this is the first time that I try to add a device in the DB. I couldn’t change the Manufacturer field.
@chris
Dim
(Angelos)
November 8, 2018, 10:36am
#11
By the way: Is your NodON Wall Switch recognized as “CRC-3100 Octan Remote Control” (as in the screenshot) or as “CBCC Domotique SAS, SW-NOD-1” ?
(or the https://nodon.fr/en/nodon/the-z-wave-octan-remote/ is recognized as a Octan Remote?)
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/249
zynex
(Michael Rydén)
November 8, 2018, 11:23am
#12
Yes, they are identified as CRC-3100 Octan Remote Control and CWS-3101 Wall Switch. The Wall Switch is the one in the link in the third post.
Octan Remote is https://nodon.fr/en/nodon/the-z-wave-octan-remote . They have the same configuration as far as a know. Just different designs.
zynex
(Michael Rydén)
November 8, 2018, 11:33am
#13
Crap, I just noticed that I posted the wrong XML file before (misread the info in PaperUI). It was for Swiid SW-ZCS-1 Cord Switch.
This is the right XML for CRC-3100 Octan Remote Control
<node>
<homeId>0xde7d7cdd</homeId>
<nodeId>6</nodeId>
<version>4</version>
<manufacturer>0x165</manufacturer>
<deviceId>0x1</deviceId>
<deviceType>0x2</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>false</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_CENTRAL_SCENE</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_MARK</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Button 1 - MONO - Controlled nodes</name>
<profile1>0x20</profile1>
<commands/>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Button 2 - MONO - Controlled nodes</name>
<profile2>0x2</profile2>
<commands/>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<name>Button 3 - MONO - Controlled nodes</name>
<profile2>0x3</profile2>
<commands/>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<name>Button 4 - MONO - Controlled nodes</name>
<profile2>0x4</profile2>
<commands/>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<name>Buttons 1 & 3 - DUO - Controlled nodes</name>
<profile2>0x5</profile2>
<commands/>
<associations/>
</associationGroup>
</entry>
<entry>
<int>7</int>
<associationGroup>
<index>7</index>
<name>Buttons 2 & 4 - DUO - Controlled nodes</name>
<profile2>0x6</profile2>
<commands/>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_CONTROLLER</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_GENERIC_CONTROLLER</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_PORTABLE_REMOTE_CONTROLLER</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__BATTERY>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
<batteryLevel>73</batteryLevel>
<batteryLow>false</batteryLow>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<versionSupported>2</versionSupported>
<maxGroups>7</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__CENTRAL__SCENE>
<sceneCount>4</sceneCount>
</COMMAND__CLASS__CENTRAL__SCENE>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>0</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>3</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>357</deviceManufacturer>
<deviceType>2</deviceType>
<deviceId>1</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_CONTROLLER_PORTABLE</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>0</interval>
<minInterval>0</minInterval>
<maxInterval>0</maxInterval>
<defaultInterval>0</defaultInterval>
<intervalStep>0</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_CONTROLLER</libraryType>
<protocolVersion>4.5</protocolVersion>
<applicationVersion>3.1</applicationVersion>
<hardwareVersion>2</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2018-11-06 10:39:12.429 UTC</lastReceived>
</node>This is the XML for CWS-3101 Wall Switch
This is for the CWS-3101 Wall Switch (basically the same as Octan Remote).
<node>
<nodeId>37</nodeId>
<deviceId>0x3</deviceId>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>7</int>
<associationGroup>
<index>7</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
</deviceClass>
<entry>
<batteryLevel>82</batteryLevel>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<configParameters>
<entry>
<int>1</int>
<index>1</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>2</value>
</entry>
</configParameters>
</entry>
<entry>
<deviceId>3</deviceId>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<autoSubscribeGroups/>
</entry>
<entry>
<applicationVersion>2.3</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2018-10-25 16:35:55.463 UTC</lastReceived>
</node>
Sorry for the wrong info I gave before.
zynex
(Michael Rydén)
November 8, 2018, 3:03pm
#14
Just activated debug logging for the z-wave module, and I actually got the scene number from the device there. This means that the scene number is received, but not handled by OpenHAB itself?
2018-11-08 16:01:05.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Application Command Request (ALIVE:DONE)
2018-11-08 16:01:05.655 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: resetResendCount initComplete=true isDead=false
2018-11-08 16:01:05.657 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2018-11-08 16:01:05.659 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
2018-11-08 16:01:05.661 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 6: Received COMMAND_CLASS_SCENE_ACTIVATION V0 SCENEACTIVATION_SET
2018-11-08 16:01:05.662 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 6: Scene activation: Scene 10, Time 0
2018-11-08 16:01:05.665 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-11-08 16:01:05.666 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SCENE_ACTIVATION, value = 10
2018-11-08 16:01:05.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Commands processed 1.
2018-11-08 16:01:05.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Checking command
Dim
(Angelos)
November 8, 2018, 3:45pm
#15
Dim
(Angelos)
November 11, 2018, 3:30pm
#16
Dim
(Angelos)
November 11, 2018, 3:42pm
#17
In both cases (CRC-3100 & CWS-3101) (xmls from here ) I couldn’t add them to the DB
I get messages that they already exist.
I don’t know why the channels get unlinked (I thought originally that it was because of missing DB info)
zynex
(Michael Rydén)
November 11, 2018, 5:19pm
#18
It’s a bit odd. The devices gets paired, and it finds everything. And they seems to work until I change any settings for the device itself. After that the channels get unlinked. They seem linked when I restart everything, but they get unlinked as soon as I push any buttons on it.
zynex
(Michael Rydén)
November 15, 2018, 4:33pm
#19
Just now, I removed one of the remotes (Octan Remote) from my system completely and also reset the remote itself just in case. Then I included it into my system again and got a new node for it. Nothing. Still the same problem.
If I press any button I get this in the logs, nothing else.
17:27:27.879 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:bf2bd99e:node51' has been updated.
This is getting a bit frustrating, none of the remotes work so I have to use the mobile app to turn on/off all lights. In PaperUI it just looks like this;
[EDIT] Out of nowhere I just got update on one channel, the battery (actually got it before to now and then), but no scene number. From the other three controllers I don’t even get battery status.
17:34:07.583 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_bf2bd99e_node51_battery_level changed from NULL to 100
zynex
(Michael Rydén)
November 16, 2018, 4:02pm
#20
Figured out a better way to use it (and it works even better). Instead of scenes, I set the controller to control a node directly instead. It’s faster, and I can use dim function within it.
