Channels missing with Philips Dimmer Switch RWL022
Hi
I ran into an issue trying to utilize a philips “dimmer switch” remote in my setup. Im using openhab 3.2 along with zigbee binding and a dongle running EmberZNet v6.7.8. So far I was able to add a few light bulbs (ledvance) and a hue smart plug. Now when I scan for my hue remote, it is discovered and a thing is created, but it lokos like it is lacking channels.
It seems like the RWL022 is not discovered as the correct type of thing… in opposition to RWL021 of which I saw some screenshots on the forum.
Also I was expecting to receive some ChannelTriggeredEvent evets of button presses in my log, but I only see events of current dimm level when I change it. Pressing the scene change button (“hue” labeled button) doesn’t fire any event at all.
Is RWL022 not supported yet? Can I circumvent this somehow by manually defining the thing?
Any hints apreciated.
Eric
Is the RWL022 basically the same as the RWL021? If so, we can easily add support - if it’s different, then someone will need to work out what the changes need to be.
I think main differnce is button scheme:
source
Would be great if it gets implemented. It’s already hard to get a new RWL021. Is there anything I can do, any file I can start looking at to adapt?
So you think it’s just the physical device that looks different but the function is the same? If so it should be easy. Please can you post the XML for this device (it’s in the userdata\zigbee folder - it will have the name of the IEEE address.
I thought so, but it looks like the “hue” labeled button is to cycle scences. And the top button is for toggling “on/off”. On the old one top button was “on” bottom was “off”.
Anyway I checked for the xml, hope it’s the correct one:
0017880109AAC5EA.xml (44.8 KB)
Would be great if you implement it. I’m happy to support… as far as I’m able to.
I think in that case it would be advisable to get a debug log. Enable logging as described in the binding docs, then sequentially press each button with a 2 second wait between each one. Send me the log of this and hopefully it will tell me what the buttons are, and I should be able to quickly produce the required configuration.
Okay,
changed logging levels as advised and took some logs.
openhab_rwl022.log (975.8 KB)
openhab_rwl022_button_presses.log (64.7 KB)
Unfortunately, pressing fourth button I didn’t see a reaction in log.
But over at zigpy project I found some related info, which indicates that there is no big difference after all, i.e. the “Hue” button behaves like “Off” on the older remotes:
Device Signature
Differences RWL021/RWL022
Thanks for looking into this
Eric
Thanks.
I’ve created a PR - it looks mostly the same as the RWL021 - the battery channels are on a different endpoint it seems, but most of the rest looks the same. As you say, the last button didn’t seem to generate a command, so that might require some change to get it working, but the other 3 looked the same as the RWL021.
Let’s see how it goes.
Gave it a quick try, device is now identified correctly and I receive button events :slightly_smiling_face:
2022-04-20 23:54:45.823 [INFO ] [openhab.event.ChannelTriggeredEvent ] - zigbee:philips_rwl022:a857212ec2:0017880109aac5ea:buttonO triggered SHORT_PRESSED
2022-04-20 23:54:46.541 [INFO ] [openhab.event.ChannelTriggeredEvent ] - zigbee:philips_rwl022:a857212ec2:0017880109aac5ea:buttonI triggered SHORT_PRESSED
2022-04-20 23:54:47.016 [INFO ] [openhab.event.ChannelTriggeredEvent ] - zigbee:philips_rwl022:a857212ec2:0017880109aac5ea:dimUp triggered SHORT_PRESSED
2022-04-20 23:54:47.769 [INFO ] [openhab.event.ChannelTriggeredEvent ] - zigbee:philips_rwl022:a857212ec2:0017880109aac5ea:dimDown triggered SHORT_PRESSED
Top button fires ON / OFF alternatingly
Dim up fires dimUp
Dim down fires dimDown
Button “hue” is not deteced.
I’ll have a closer look on the weekend.
Thanks Chris!
Thanks for the quick feedback :+1:
I’m not sure why the bottom button doesn’t send anything (at least according to the log). It might be that it needs another bind command sent to the remote to receive different commands. If I find some time over the next few days I will take a look at the link you sent above as they might shed some more light on this. I did look at them earlier, but without delving deeper into the zigpy code it’s not immediately obvious what they do…
@chris Did you ever get to take a look? I am observing the same thing as @iengineer .
I guet ON / OFF from the top button, but the “hue” button does nothing. I have a use for that button so I would be very happy to have it working.
I am in the same boat, so if anyone has any solution/work-around please chime in. Would it work to go through an Hue bridge? Can I help with the binding in any way?
Hi friends. Any progress on the bottom button on the RWL022 please? There is no channel associated with the bottom button marked “hue”. I have openHAB 4.1.1 on RPi 5 with Sonoff Zigbee 3.0 USB Dongle Plus.
@steinmetz sorry but I only just noticed this thread just now. Are you using the Hue API v1 or v2? (Please post the thing uid of your RWL022 which will indicate that). I don’t have any RWL022 in my house to test, but I am pretty sure that if you use API v2 then that button will be visible.
In my prior post I mistakenly thought that you were using the RWL022 on the Hue binding; but I realise that you were actually referring to the Zigbee binding.
Nevertheless, I can confirm that the RWL022 does work properly on the Hue binding, and that that binding does report the status of all four of its buttons.
@AndrewFG thank you for your answer. So you’re saying that if I buy a Philips Hue Bridge v2, I’ll be able to respond to the “hue button press” event in OpenHAB?That sounds good, thanks.
Yes. .. but buying a bridge to get just one button press might be financial over-kill :wink:
:smiley: :smiley: :smiley: I would like to buy such switch for every room. So far I’m only in the testing phase. I also tested the IMMAX NEO Smart Knob and unfortunately with a similar result. With this switch I can turn the light on and off, adjust the brightness, but the long press to trigger the scene switch unfortunately doesn’t work like the hue button on the RWL022.
