Can I make a chart with a temperature (in the 20s) and a switch, so I can see when the switch is on.
I think I’ve done it, but I think it’s treating the on and off as 1 and 0. How can I get the switch to register the on/off as say 0 and 10 so it’s closer to the temperature scale?
Are you using OH1 or OH2? In OH1 the ON/OFF value of the switch is transformed to 0/1, so that it can be displayed on a chart. In OH2, this is not possible (at the moment). You can however define a number item and create a rule which sets the number item to 0/1, according to the switch state. And then display the number item in the chart.
With this rule, you can also set the value to 0/10 instead of 0/1.
