Chart Bar Aggregated - Card from ScrewPlate
It’s a widget that displays only one item in the chart, and you can customize the chart’s appearance slightly, for example, by changing the unit of measure, the bar color, and the starting year.
ScrewPlate will be a template set with various widgets, all of which are highly customizable in a unified style. More information on [GitHub](GitHub - DrScr3w/ScrewPlate: Customizable widget templates for openHAB · GitHub)
## Screenshots
## Changelog
In each widget there is a tag with version, please always make sure to use the latest version.
Change and further information on [GitHub](GitHub - DrScr3w/ScrewPlate: Customizable widget templates for openHAB · GitHub)
## Resources
https://raw.githubusercontent.com/DrScr3w/ScrewPlate/refs/heads/main/templates/Card_Template_Chart_Bar_Aggregated.yaml
