Chart doesn’t show correct tooltip by markArea
Hello everyone!
What I want to have:
I’ve created and chart in my OH 4.2.2 to visualize my thermostat values for set temperature, current temperature AND humidity. I also want to display the state of a second item, if the window is OPEN or CLOSED. So far so good.
Problem:
Now I have the problem that not all values are always displayed in the tooltip.
If I make a hover on the green lower area, the thermostat values are displayed, but the “Fenster“ will display „NaN“. If I do a hover above the green line (Set temperature), I only have the OPEN window value but no other thermostat values. If I am in a non-pink area, where the window should actually be CLOSED, it also says NaN.
I have added a few screenshots to clarify this.
I know that the value from “Fenster (markArea)” is displayed for the upper tooltip and the value from “Fenster (oh-time-series)” is displayed in the lower tooltip. I don’t know why! Both are in one component.
Here is my chart code
  chartType: ""
  label: "Heizkorper Schlafzimmer: IST / SOLL / Luftfeuchtigkeit"
  period: D
slots:
  dataZoom:
    - component: oh-chart-datazoom
        type: inside
  grid:
    - component: oh-chart-grid
        includeLabels: true
  legend:
    - component: oh-chart-legend
        bottom: 3
        type: scroll
  series:
    - component: oh-time-series
        gridIndex: 0
        item: RST2HeizkorperthermostatSchlafzimmer_AktuelleTemperatur
        markLine:
          data:
            - type: average
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
            backgroundColor: auto
        name: Aktuelle Temperatur
        type: line
        xAxisIndex: 0
        yAxisIndex: 0
        areaStyle:
          opacity: 0.2
        gridIndex: 0
        item: RST2HeizkorperthermostatSchlafzimmer_Solltemperatur
        markLine:
          data:
            - type: average
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 0
        gridIndex: 0
        item: RST2HeizkorperthermostatSchlafzimmer_Luftfeuchtigkeit
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 1
        areaStyle: {}
        gridIndex: 99
        item: WDS_Fenster_Schlafzimmer_2_TurFensterstatus
        name: Fenster (oh-time-series)
        type: line
        connectNulls: true
        xAxisIndex: 0
        yAxisIndex: 0
      slots:
        markArea:
          - component: oh-mark-area
              name: Fenster (markArea)
  tooltip:
    - component: oh-chart-tooltip
        _trigger: axis
        confine: true
        smartFormatter: true
  xAxis:
    - component: oh-time-axis
        gridIndex: 0
  yAxis:
    - component: oh-value-axis
        gridIndex: 0
        max: "40"
        min: "10"
        gridIndex: 0
Can someone please help me?
I’ve been trying for many days.
Many THX
This is, as far as I know, just the default functioning of the e-charts tooltip. Because the data shown for the mark area and the line series is fundamentally different (note that the markarea tooltip shows the range of datetimes for that area, not the exact datetime of the cursor), e-charts is not going to combine them.
The reason that you have the Fenster (oh-time-series) added to the time series tooltip is that you have added the item and name configs to the time series itself which is not required if you just want the mark area.
I am not aware of a way to achieve what you are looking to do, although there is a small chance that you might be able to use e-charts tooltip formatter for this.
Many thanks @JustinG for your support and advice.
I spent 2 more long evenings trying several eChart things. I have NOT found a solution to bring both tooltips together.
I am happy with my solution so far. I have given “humidity” an additional “areaStyle” with opacity, so I also get my 3 most important return values displayed under this area: target, current and humidity
Above “yellow” it shows the duration when a window was open. In the “white area” there is nothing about the window, but my important values - it fits :wink:
Here are the current screenshots with the 3 scenarios:
Here is the current YAML chart code:
  chartType: ""
  period: D
slots:
  dataZoom:
        type: inside
  grid:
        includeLabels: true
  legend:
        bottom: 3
        type: scroll
  series:
        gridIndex: 0
        markLine:
          data:
            - type: average
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 0
        areaStyle:
          opacity: 1
        gridIndex: 0
        markLine:
          data:
            - type: average
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 0
        areaStyle:
          opacity: 0.2
        gridIndex: 0
        smooth: true
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 1
        areaStyle: {}
        gridIndex: 0
        type: line
        connectNulls: true # Lücken schließen
        xAxisIndex: 0
        yAxisIndex: 0
      slots:
        markArea:
  tooltip:
        _trigger: axis # Tooltip synchronisiert auf alle Achsen
        confine: true
  xAxis:
        gridIndex: 0
  yAxis:
        gridIndex: 0
        max: "40"
        min: "10"
        splitArea:
          show: true
        splitNumber: 5
        gridIndex: 0
        max: "80"
        min: "20"
        splitNumber: 5
I still have two questions that I couldn’t solve by trying and trying again:
  1. Where can I set the opacity of my red “markArea” for the window status?
    (Nothing is accepted in “areaStyle”. “color” would work directly in config.)
        areaStyle: {}
        gridIndex: 0
        type: line
        color: red
        xAxisIndex: 0
        yAxisIndex: 0
      slots:
        markArea:
  1. Why can’t I make my lines rounder using “smooth: true”, but they all remain square?
        areaStyle:
          opacity: 0.2
        gridIndex: 0
        smooth: true
        markPoint:
          data:
            - name: min
              type: min
            - name: max
              type: max
          label:
        type: line
        xAxisIndex: 0
        yAxisIndex: 1
Thanks again
Add itemStyle to the markArea config, and then add color to the itemStyle:
It probably is smoothing it just a little bit. The problem is that because your persistence data is every minute, you’re not really going to get much smoothing . If you add a data zoom and zoom in to a very high degree you’ll see the smoothing at the minute level like this:
Hi there!
Many thanks, that worked for me!
color I don’t need, but opacity is the right thing.
        areaStyle: {}
        gridIndex: 0
        type: line
        connectNulls: true
        xAxisIndex: 0
        yAxisIndex: 0
      slots:
        markArea:
              itemStyle:
                opacity: 0.6
I tried to zoom in and saw a little bit of smoothing :grin:
For me I have found the solution
THX @JustinG
