Check if the state's item is the same for X seconds
If the power energy consumption goes down into x-y range for z seconds, then I would like to fire the rule.
rule “play”
when Item b changed
if (b.state >=10 && b.state <= 50)
if(!b.changedSince(now.minusSeconds(1))),
[|b.sendCommand(OFF)]
My code is not working. :frowning:
Thanks for pointing me into the right direction.
needs to be
if (!b.changedSince(now.minusSeconds(1)))
b.sendCommand(OFF)
Also, b cannot be of integer type (for state comparison) and OnOffType (in sendCommand) at the same time
Also, you must be sure that you properly persist the b item on everyChange (which doesn’t work for me). Do debug prints to see if what’s stored in persistence database now and X seconds ago really differ.
I wouldn’t use persistence here anyway but global variables.
As the rule gets triggered by
Item b changed
there is no chance that the condition
if( ! b.changedSince(now.minusSeconds(1)) )
will ever get true.
