Today is day 3 of me playing with openhab, so a total noob,
I’m trying to set up a rule where when one device received a status update,
I want to check the current state of my light and then depending on if the light is on turn it off and vice versa,
I would think this is a very simple task but i just cannot get it to work.
below is what i have put in the rule
Item status is just a place holder to receive an mqtt command from a button (im not sure if that is the correct way to do it but…)
rule "light check"
Item status received update
if (mySwitch.state == ON)
sendCommand(mySwitch, ON)
else {
sendCommand(mySwitch, OFF)
rule "light check"
if (status.state == ON) {
else if (status.state == OFF) {
You were checking the wrong item in your if statement. Also, it’s possible that the status variable is set to something other than ON or OFF, like Uninitialized, so I made the logic more explicit.
This is fantastic,
having an else if worked like a charm,
now i have a it set as (cause i want the light to turn on when its off and off when its on)
Huge huge thank you,
May its a good idea to just take a small break and relook at your work when a logical thing doesn’t want to work
rule "light check"
if (mySwitch.state == OFF)
else if (mySwitch.state == ON) {
