I have a rule triggering our vacuum robot to clean our apartment at certain days (MON, WED, FRI).
This works fine and I do not intend to change it, BUT
I want to check how long nobody has been home and then decide if to run the vacuum or not.
Why ? If we are on vacation, we do not need the vacuum to run.
The idea:
check if item gPresence has the state “OFF” (item gPresence is a switch typ): this is easy
check how long gPresence has been in “OFF” state: this is where I need help
++ My idea is to check (e.g.) if gPresence has been in “OFF” for longer than 3 days. If it has been in “OFF” for that long, it’s considered we are on vacation.
++ I’d check when gPresence was last updated and (gPresence.lastUpdate)
decide to either continue with the rule or not: this is easy
My persistance is influxdb.
if (gPresence.state == OFF){
val DateTime lastUpdate == gPresence.lastUpdate
val days_between = lastUpdate.until(now, ChronoUnit.DAYS)
if (days_between >= 3){
return;
else {
... // continue with rule
Am I on the right path ? Or can my idea be solved easier ?
Should be possible to check with gPresence.previousState(true).timestamp.
The true parameter is: the previous state must be different from the current state. So if gPresence.state is OFF, gPresence.previousState(true).timestamp should give you the time (and date) when gPresence changed from ON to OFF.
I just have an away switch and turn that on when I am on holidays etc so the front gate doesn’t open and also when the away is on it sets random lights on and off etc and don’t do things that I need doing when I am at home. (opening curtains etc)
