Hi there!
I want to use the chromecast binding for my google home,
the problem is that the binding needs to use the Callback URL for playing audio files.
but my openhab page is protected by nginx, and i can’t add a username and password in the binding settings.
I tested with nginx disabled and then its working fine!
changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unable to load media
this is my nginx file:
server {
listen 80;
server_name xxx.duckdns.org;
return 301 https://$server_name$request_uri;
}**server {
** listen 443 ssl;**
** server_name xxx.duckdns.org;**** ssl_certificate /etc/letsencrypt/live/xxx.duckdns.org/fullchain.pem;**
** ssl_certificate_key /etc/letsencrypt/live/xxx.duckdns.org/privkey.pem;**
** add_header Strict-Transport-Security “max-age=31536000”;**** location / {**
** proxy_pass http://localhost:8080/;**
** proxy_set_header Host $http_host;**
** proxy_set_header X-Real-IP $remote_addr;**
** proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;**
** proxy_set_header X-Forwarded-Proto $scheme;**
** auth_basic “Username and Password Required”;**
** auth_basic_user_file /etc/nginx/.htpasswd;**
** }**** #### When using Let’s Encrypt Only ####**
** location /.well-known/acme-challenge/ {**
** root /var/www/xxx.duckdns.org;**
