Did anything else get updated at this same time? Because OH has nothing to do with the SAMBA configuration. openHABian sets up a share to mount folder from the RPi to Windows. But it looks like you are trying to mount folders shared by Windows to the RPi which is definitely going to be outside the scope of what OH or openHABian has control over.
Thanks for your answer. Nothing changed on the configuration of my Windows device. I am still able to connect to these shares from another Windows machine and also via App from my iOS device. So this share and other shares are definitively accessible with this user.
Are there more logs regarding this connection to check what the problem is?
There are probably samba logs somewhere. But really, this is all outside the scope of OH and openHABian so you probably will not find a whole lot of help on this forum. You might find more on a generic RPi forum or samba forum or the like.
You may not of changed the share itself, but Windows updates may of change security of Windows File sharing in general. I run into issues when the SMB protocol is no longer set to NT1.0 (based on how I read your mount command); while this may not be the exact problem, you may want to research mounting Windows shares via SMB2 or SMB3.
