Circular dependencies / startup issues resolved
All,
the latest build #399 now includes a couple of fixes for the startup behavior, which should fix quite some issues like this one.
I strongly recommend to upgrade to this build if you had any issues with your startup rules, etc, in the past as I expect it to be much more reliable during startup.
Best regards,
Kai
Hi Kai,
So I’ve upgraded to todays runtime - everything updated to the online version except for retaining the userdata folder.
I then installed the zwave binding, and I get the following logged - this is all. Any thoughts?
openhab> log:display zw
10:14:17.830 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent INSTALLED - org.openhab.binding.zwave
10:14:18.501 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent RESOLVED - org.openhab.binding.zwave
10:14:20.058 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent STARTING - org.openhab.binding.zwave
10:14:20.060 [DEBUG] [inding.zwave.internal.ZWaveActivator] - Z-Wave binding started. Version 2.0.0.201607080102
10:14:20.095 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=zwave:qubino_zmnhba_00_000, thing.id=zwave:device:1531045fdae:node12, service.id=439, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.097 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=440, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.101 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=zwave:tkb_tz88_00_000, thing.id=zwave:device:1531045fdae:node13, service.id=441, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.103 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=442, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.106 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=zwave:fibaro_fgd211_00_000, thing.id=zwave:device:1531045fdae:node2, service.id=443, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.108 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=444, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.111 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=zwave:fibaro_fgd211_00_000, thing.id=zwave:device:1531045fdae:node4, service.id=445, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.113 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=446, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.123 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=zwave:serial_zstick, thing.id=zwave:serial_zstick:1531045fdae, service.id=447, service.bundleid=204, service.scope=singleton} - org.openhab.binding.zwave
10:14:20.124 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, component.id=295, service.id=438, service.bundleid=204, service.scope=bundle} - org.openhab.binding.zwave
10:14:20.195 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.zwave.ConfigDescription, component.id=296, service.id=448, service.bundleid=204, service.scope=bundle} - org.openhab.binding.zwave
10:14:20.197 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent STARTED - org.openhab.binding.zwave
Then better don’t retain it and see if it makes a difference. I tried the offline distro and Z-Wave seems to start up alright.
Ok - I’ll give it a try. I was trying to avoid that as I will need to reinstall all things :frowning:
Ok - that did fix it. I suspect that whatever is/was causing the issue with the callback may also be the issue that was stopping the binding from starting as I also had this on the weather binding.
Anyway - it’s working now, and I just need to reinstall my 50 zwave things :frowning:. I don’t suppose there’s a way to backup/export the mapdb database?
Similar situation here:
The update of an existing installation (via the script from this forum) was not working, the console didn’t even start properly.
Installing the online distribution in an empty directory and copy of the conf files worked. And from a first look it seems like the startup issues are resolved.
@chris, did you try to only copy the mapdb folder?
Yes - that caused it to die.
Ah - and just to confirm that I also copied the other ā€˜user’ type folders (ie other than log, cache, etc…) and it still works, so I’m pretty confident the issue is in the mapdb.
Hmmm - I’m still seeing an issue with one of my bindings not starting -:
13:01:34.674 [DEBUG] [org.openhab.binding.meteostick      ] - BundleEvent STARTING - org.openhab.binding.meteostick
13:01:34.683 [DEBUG] [org.openhab.binding.meteostick      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.meteostick.internal.meteostickHandlerFactory, component.id=196, service.id=335, service.bundleid=203, service.scope=bundle} - org.openhab.binding.meteostick
13:01:34.687 [DEBUG] [org.openhab.binding.meteostick      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=meteostick:meteostick_bridge, thing.id=meteostick:meteostick_bridge:155cf0d3f4e, service.id=336, service.bundleid=203, service.scope=singleton} - org.openhab.binding.meteostick
13:01:34.692 [DEBUG] [org.openhab.binding.meteostick      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=meteostick:meteostick_davis_iss, thing.id=meteostick:meteostick_davis_iss:155cf0dee5d, service.id=337, service.bundleid=203, service.scope=singleton} - org.openhab.binding.meteostick
13:01:34.694 [DEBUG] [tick.handler.meteostickSensorHandler] - Initializing MeteoStick handler.
13:01:34.695 [DEBUG] [org.openhab.binding.meteostick      ] - BundleEvent STARTED - org.openhab.binding.meteostick
Other than recompiling periodically, this binding has worked find for the past 8 months or so and this problem started a couple of weeks back. Maybe it’s not related to the previous startup issues, but it’s something I’ve not seen until recently so I’m suspicious.
I did a from-scratch reinstall on my test system using the latest snapshot.
The startup is much cleaner, but I still see cases where the binding initialization does not proceed.
This seems to be something different then. Do we already have an issue at ESH that describes what exactly ā€œbinding initialization does not proceedā€ means?
I don’t believe so. If you’d like, I can open an ESH issue that describes the behavior that’s outlined in this and other threads.
Thanks, definitely good to have it entered there to keep track.
I just entered the issue. The title may not be worded all that well, so feel free to edit it.
@chris, Feel free to add/edit based on your observations.
Hopefully resolved with build 407 now - please test!
As I reported over on this thread, this build looks really good.
I also can confirm for me the latest build (#408) fixed the startup issues on my side.
@Kai thanks for all the work to find the cause of this and fix it!
