I have run into a classcastexception that I am unable to solve. In the helios binding we use javax.ws.rs.Client, which is provided by the runtime (cfr output from “bundle:capabilities”):
javax.ws.rs-api_2.0.1 [35] provides:
osgi.wiring.package; javax.ws.rs.client 2.0.1 required by:
org.glassfish.jersey.core.jersey-server_2.22.2 [126]
org.glassfish.jersey.core.jersey-client_2.22.2 [124]
org.glassfish.jersey.core.jersey-common_2.22.2 [125]
org.glassfish.jersey.media.jersey-media-sse_2.22.2 [128]
org.openhab.binding.helios_2.5.10.202010140401 [287]
However, when the helios bundle is running, and when a call is made to javax.ws.rs.client.ClientBuilder(), I do get the following error
Exception occurred while initializing handler of thing 'helios:ipvario221:gate': ClassCastException: attempting to castbundleresource://35.fwk1058650291/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk1058650291/javax/ws/rs/client/ClientBuilder.class
java.lang.LinkageError: ClassCastException: attempting to castbundleresource://35.fwk1058650291/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk1058650291/javax/ws/rs/client/ClientBuilder.class
at javax.ws.rs.client.ClientBuilder.newBuilder(ClientBuilder.java:97) ~[?:?]
at org.openhab.binding.helios.internal.handler.HeliosHandler221.initialize(HeliosHandler221.java:173) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor102.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
What surprises me is that class being referenced (35.fwk1058650291) is the same. If it would be different then I could imagine that another bundle is exporting a javax.ws.rs provider, but is not the case
When I beef up the POM and feature.xml to include Glassfish directly, e.g.
For anyone encountering the same problem, it is linked to the kar cache being rebuilt (after being wiped out), and so, in my case the problem went away “automagically”
