After I updated to 1.8 RC Classic UI does not load in browser, I just get loading…
Android App is working fine.
/mike
/mike
I have the same issue
I get an initial ClassicUI load of the sitemap home page, but clicking on any group to expand it does not work…
+1 I am getting a spinning wheel and “Loading” on the web ui…
It’s also failing for me. I see this in chrome’s console:
GET https://192.168.1.2:8443/%22https://192.168.1.2:8443/classicui/WebApp/Design/Img/loader-gray-100x12x2.png%22 404 (ProxyServlet: /%22https://192.168.1.2:8443/classicui/WebApp/Design/Img/loader-gray-100x12x2.png%22)
Logic.min.js:1 TypeError: Cannot set property 'innerHTML' of undefined
at Slider.that.displayValue (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:21288)
at new Slider (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:21311)
at InitSlider (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:21889)
at InitForms (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:22181)
at ShowAsync (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:15878)
at https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:14643
at __callback (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:16659)
at XMLHttpRequest.c (https://192.168.1.2:8443/classicui/WebApp/Action/Logic.min.js:1:27059)
Now I have updated to final 1.8 and I still have the problem.
Should I downgrade to 1.7.1?
/Mike
I’ve just upgraded to 1.8 and have the same issue - page just sits at “Loading”. Happens with both Chrome and Safari.
Fixed: once I deleted the sliders in my sitemap, it worked for me.
You can have one, just not more then one.
Ok, the faulty case is that you have a Slider in the sitemap without a label that contains the value.
So: Slider item=DimmedLight label="Dimmer [%s]"
should work, but Slider item=DimmedLight label="Dimmer"
not.
I’m fixing that.
@sebastian, is it correct that the issue you are fixing in github is #2900?
Not directly, just quick fixing the 1.8 Slider. The PR in some minutes is for that.
2900 has to be fixed, later, too.
