Classic UI - Gauge web element
Hi all,
below an example of gauge elements for classic ui:
Required files:
<html>
<head>
    <style>
        body {
             margin: 0px;
    </style>
            - Google jQuery API
            - Google Charts API (https://developers.google.com/chart/)
            - openHAB API
    <script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js"></script>
    <script type="text/javascript">
        var baseURL = "../../";
    </script>
    <script type="text/javascript" src="../javascript/openHAB.js"></script>
</head>
<body>
    <script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>
     <center>
       <div id="chart_div"></div>
     </center>
        // Load package and register callback ...
        // https://developers.google.com/chart/interactive/docs/gallery/gauge
        google.charts.load('current', { 'packages': ['gauge'] });
        google.charts.setOnLoadCallback(draw);
        function draw() {
            var openHABValue = Math.round(GetOpenHABItem("ItemPowerHouseTotal"));
            var data = google.visualization.arrayToDataTable([
                ['Label', 'Value'],
                ['[W]', openHABValue]]);
            var options = {
                min       : 0,
                max       : 3000,
                width     : 110,
                height    : 110,
                redFrom   : 2000,
                redTo     : 3000,
                yellowFrom: 1000,
                yellowTo  : 1999,
                minorTicks: 250
            var pageElement = document.getElementById('chart_div');
            var powerGauge = new google.visualization.Gauge(pageElement);
            powerGauge.draw(data, options);
            setInterval(function () {
                data.setValue(0, 1, openHABValue);
            }, 2500);
    </script>
</body>
</html>
Gauge.html:
<html>
    Parameters
      item: openHAB item
      unit:
<head>
    <style>
        body {
             margin: 0px;
    </style>
            - Google jQuery API
            - openHAB API
    </script>
</head>
<body>
     <center>
     </center>
    $(document).ready(function () {
        var item = GetParameter("item");
        var unit = GetParameter("unit");
        function draw() {
            var openHABValue = Math.round(GetOpenHABItem(item));
                ['Label', 'Value'],
                ['[' + unit + ']', openHABValue]]);
            var options = {
                min       : 0,
                max       : 3000,
                width     : 110,
                height    : 110,
                redFrom   : 2000,
                redTo     : 3000,
                yellowFrom: 1000,
                yellowTo  : 1999,
                minorTicks: 250
            }, 2500);
    </script>
</body>
</html>
openHAB.js:
// * Required definitions:
// *  - var baseURL = "../";
// * Required API
// * - Google jQuery: https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js
function _GetData(itemUrl) {
    var itemValue = null;
    $.ajax({
        contentType: 'text/plain',
        url: itemUrl,
        data: {},
        async: false,
        success: function (data) {
            if (data != "NULL") {
                itemValue = data;
    return itemValue;
// JSON to CSV Converter
function _ConvertToCSV(objArray) {
    var array = typeof objArray != 'object' ? JSON.parse(objArray) : objArray;
    var str = '';
    for (var i = 0; i < array.data.length; i++) {
        var line = '';
        for (var index in array.data[i]) {
            if (line != '') line += ','
            line += array.data[i][index];
        str += line + '\r\n';
    return str;
function GetOpenHABItem(item) {
    var itemUrl = baseURL.concat("rest/items/").concat(item).concat("/state/");
    return _GetData(itemUrl)
function GetOpenHABItemIntValue(item) {
    return Math.round(GetOpenHabItem(item));
function GetOpenHABItemHistoryJSON(item) {
    var itemUrl = baseURL.concat("rest/persistence/items/").concat(item);
    var jsonData = null;
    jsonData = _GetData(itemUrl);
    return jsonData;
function GetOpenItemHABHistoryCSV(item) {
    var jsonData = GetOpenHABItemHistoryJSON(item);
    return _ConvertToCSV(jsonData);
function GetParameter(parameterName) {
    var result = null,
        tmp = [];
    location.search.substr(1).split("&")
        .forEach(function (item) {
          tmp = item.split("=");
          if (tmp[0] === parameterName) {
              result = decodeURIComponent(tmp[1]);
    return result;
hope it is of use :slight_smile: …
with kind regards,
Patrik
I do not really know, what I should do?
  1. put “Gauge.html” to “OpenHAB2\conf\html” folder
  2. put “openHAB.js” to “OpenHAB2\conf\scripts”
What to do with the first htmp-file with no name?
Can you share a sitemap example?
