I’m a complete beginner to OpenHAB… would like to eventually get into more complete HA (lights, locks, switches, etc) but figured I’d get my feet wet with one of the few HA items I have: my Nest thermostat. For background, I’m running OSX Mavericks.
Downloaded the latest OpenHAB package and Addons from the OpenHAB website and copied the application folder to my Applications directory. Copied (only) the Nest binding to the addons directory. Signed up as a Nest developer and got all my keys and codes copied into the relevant section of the openhab.cfg (which is a straight copy from openhab_default.cfg).
Here’s my nest.items file:
String home_away "Home/Away [%s]" <present> { nest="=[structures(Home).away]" }
DateTime Nest_last_connection "Last Nest Connection [%1$tm/%1$td %1$tH:%1$tM]" {nest="<[last_connection]"}
String NestHome_name "Name [%s]" {nest="<[structures(Home).name]"}
DateTime NestTStatUpstairs_last_connection "Last Connection [%1$tm/%1$td/%1$tY %1$tH:%1$tM:%1$tS]" <calendar> {nest="<[thermostats(Hallways).last_connection]"}
And here’s my nest.sitemap file:
sitemap nest label="Nest"
Frame label="Home" {
Switch item=home_away mappings=[home="Home",away="Away"]
Text item=Nest_last_connection
Text item=NestTStatUpstairs_last_connection
I also copied the logging text from the Nest GitHub page into my logback file.
Started OpenHAB (“sudo sh start.sh” and the terminal showed no errors or anything to suggest something was wrong:
$ sudo sh start.sh
Launching the openHAB runtime...
osgi> 2015-10-19 10:02:13.573 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.1).
2015-10-19 10:02:14.601 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2015-10-19 10:02:14.661 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2015-10-19 10:02:16.422 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2015-10-19 10:02:24.125 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'nest.sitemap'
2015-10-19 10:02:24.246 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'nest.items'
2015-10-19 10:02:25.068 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
However, when I go to my OpenHAB website, it shows no Nest data:
The terminal window shows no Nest binding updates (or updates of any kind beyond what I pasted above) and the nest.log is empty. No other log files show any Nest binding messages.
I’ve deleted and re-downloaded the OpenHAB and add-on archives and re-created the above setup, being careful not to change anything else from the defaults. Same problem. If I had to guess, the Nest binding either isn’t installed correctly (or isn’t being caught by OpenHAB when run) or it can’t talk to the Nest site… but it’s strange that I’m not even getting an error. I’ve tried changing the name of my Nest structure and devices (in an earlier attempt, when I was also trying to call up Nest device info) to what I know is incorrect and even that’s not throwing up an error, as I would expect.
Any ideas on what I’m doing wrong?
