I currently have one ethernet gateway and three nodes on my MySensors network. It is pretty small, but will be growing quickly, and soon. MySensors makes it very easy.
I have a node that was automatically assigned ID 105 via the gateway before I was able to reflash it to use the ID that I wanted it on.
It was automatically assigned 105, and I later reflashed it to 14. I still see Openhab2 trying to talk to ID 105.
[DEBUG] [orsAbstractConnection$MySensorsWriter] - Sending to MySensors: 105;255;3;0;18;
How do I get rid of these?
I found this file:
/var/lib/openhab2/mysensors/cache/given_ids_mysensors_bridge-eth_dn_br1_gw.cached
which has this in it.
[0,1,2,3,105,14]
Should I remove this file, so that it recreates it on restart?
Should I remove only 105?
I presume my steps are
- stop openhab
- edit or remove file, as is best
- start openhab
Thank you for your time.
