I want to control the room temperature. I am measuring the temperature using a Sonoff sensor and also able to control the AC temperature using Broadlink RM Mini 3.
Has anybody written a rule which turns ON/OFF the AC based on room temperature?
I guess I am trying to mimic Nest thermostat in software.
There are many examples on the forum just use the search function.
One rule example:
rule "Elutoa temperatuur"
Item ElutoaSetpoint changed or
Item ElutoaTemp changed
var Number cur_temp = ElutoaTemp.state as Number
var Number setpoint = ElutoaSetpoint.state as Number
val Number hysteresis = 0.5
if (cur_temp < (setpoint - hysteresis)) {
if (ElutoaRadikas.state != ON) {ElutoaRadikas.sendCommand(ON)}
else if(cur_temp > setpoint + hysteresis) {
if (ElutoaRadikas.state != OFF) {ElutoaRadikas.sendCommand(OFF)}
