This device doesn’t seem to be in the database - I guess it probably has another name. Please provide the database link, and also your XML file that OH generates.
That’s what you provided above (ie the link to the database entry).
It depends on your system, but somewhere there will be a userdata folder, and in there is a zwave folder which will contain an XML with the name of the node ID.
I’ve update the database. I’ll try and do a binding update today some time. You will need to delete, and add back the thing so that it picks up the latest definition.
thanks, I’ve uninstalled the thermostat thing and reinstalled, but no change.
I have also uninstalled and reinstalled the zwave binding, and again no result.
Do I have to manually download a new zwave binding with your changes in it?
If so how do I do that, by getting the latest snapshot?
