I am having issues with an Aeotec Nano Dimmer and Wall Swipe - there is a night light function that doesn’t seem at all to work right when I set the on/off time - apparently the Wall Swipe/Dimmer relies on a Clock SET command must be used in Z-Wave to set the time frame of your Nano Dimmer according to Aeotec support.
They mentioned this as well:
“you may need to use OZWCP to access the Clock Command Class as i don’t believe most softwares do not allow easy access to this.”
I tried to search on here and google about clock channel on zwave/OH2 but no luck.
Parameter 84 allows you to set and on/off time for the night light (which by the way is explained wrong/incorrect on that github site. As the HEX needs to be converted to DEC to get the 24-hr time).
the 0x12 = 18 in DEC which is 18:00/6pm according to Aeotec support.
Either way, the issue for me is that it seems the device isn’t aware of the correct time
We seem to be discussing different things maybe? The command referenced as I understand it is a part of the ZWAVE protocol which is why it can be set by OZWCP.
I appreciate the banter either way - never hurts to throw things out there. I’ve been at this for a few days now, searching, reading docs, trying all kinds of setting changes… It’s the only reason why after speaking with Aeotec to confirm a few things that I understand that my thoughts the dimmer doesn’t know what time it is, is the culprit.
Now I just hope it can be resolved or I will have to randomly start guessing at time offsets to get me close
I’m not worried about the parameters. A number is a number - hex or decimal the binding is just getting a number.
I’ll take a look at the database and see if the clock channel is on this device (presumably not) and if not will add it. It should not be an issue as this has been supported in openHAB for many years.
That is what you need. This is the time set command, and using this channel will keep the time set correctly. The value that it gives is the offset from nominal time, but if it gets “too far” off, it will automatically be set.
The clock setting is automatic. You should just need to specify this channel and it should set the time whenever it gets a certain amount away from the PC time (I forget the numbers now).
